misfire
Old Feb 20, 2006 | 01:21 PM
t2slt1's Avatar
misfire
check engine light comes on then goes off this time it staid took car "02ls1 45k miles" to auto zone ran codes and came up cylinder 7 misfiring. Anyone with this problem are knows what could be causing it?
Old Feb 20, 2006 | 01:44 PM
Kataklysm's Avatar
Re: misfire
It's most likely a bad plug or plug wire.
Old Feb 20, 2006 | 09:06 PM
t2slt1's Avatar
Re: misfire
whats the best plugs and wires ?
Old Feb 20, 2006 | 10:00 PM
lineybiker_11's Avatar
Re: misfire
listen i got the same problem with my 99 z 57k. i took it to two different places to have it ran on there machines both said # 7 misfire. they told me plugs wires. changed it, same thing happened went and bought a new coil, same thing. had it put on a machine again, they said it was a dead short in the alternator. took it off had it cheacked it was still good, put it back i was pissed. took it to the dealer to have it fixed they told me i had pluged fuel injectors they did a fuel system flush and it got better but still had the miss so they took em out and they were still pluged. so i am ordering a set of fuel injectors from fast hopefully that will fix it i think they were like $300 for the set so not to bad. but i would take it to a dealer to have it cheacked cuz by the time i payed the shops the run it on their machines i payed $150 plug another $150 for plugs and wires that i didn't really need but they are nice. i only paid $150 for the dealer to run it on there machine and flush the fuel system so i know thats all clean.
Old Feb 21, 2006 | 08:27 AM
teke184's Avatar
Re: misfire
no need to go crazy on the plug wires.
some $45 taylor spiro-pro wires work fine, and get some tried-and-tested NGK tr55 plugs for $2 each.
see if that helps.
if not, swap the coils around
then try swapping the injectors around.
if the miss moves cylinders than you know you have a problem with whatever you changed.
Old Feb 21, 2006 | 01:41 PM
Re: misfire
it gave me a good reason to get the good plugs and wires i wanted though
Old Feb 21, 2006 | 07:46 PM
t2slt1's Avatar
Re: misfire
guys thanks for the info, all of these items i want to upgrade anyway. Which one is cylinder 7? so i can get started how hard is it to swap your own injectors?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
