Mcleod street twin owners come inside
Old Aug 15, 2002 | 12:46 PM
vhgjk123's Avatar
Question Mcleod street twin owners come inside
Hi, i just got my street twin put on the other day and i have a couple of questions. First of all when starting from a dead stop, when i let out the clutch and give it gas it makes the whole car shake as if its about to stall. When i give it more gas it helps take the shake out of the start. I was wondering if this will go away or if everytime i am driving in traffic i have to start from a stop like i am trying to launch the car at the dragstrip? Also, i noticed i only have to put the clutch halfway in to shift gears. I was wondering if this is hard on the clutch for daily driving? Should i put the clutch to floor everytime to shift even though i dont have to?
2000 SS Camaro
free mods, K&N Air Filter, Air Temp Module
13.45 @105.48mph on Bald Tires
Old Aug 15, 2002 | 01:47 PM
SSnyper's Avatar
Post
I have heard that these clutches chatter when they are new, but most of this should disappear as the facings wear. I would suggest driving the car gently for the first several hundred miles. And you only need to depress the clutch as far as necessary to change gears smoothly.
2002 Camaro SS Sebring Silver hardtop with ebony leather, Hurst Shifter, !CAGS, BMR chrome-moly STB, SLP lid, bellows, & ATS adapter, PS filter, METCO LCA's & bolt-in driveshaft loop
1986 Buick Regal T-Type TE44, stock intercooler with the fat neck, .030" JE's, RJC girdle, P & P'd heads with Ferrea valves, head studs, custom camshaft, 55 lb injectors, ATR downpipe, wastegate, ram air & exhaust, converter by Alan, Hot-wired 340 pump, Bilstein shocks, Enkei GNX-style wheels, Ultralite gauges, and the whole METCO catalog
1987 Buick Regal Turbo T 'Old Gray' GM Hi-Tech Magazine's project car Jack Merkel custom bullet, Stage 5 60-1 turbo, DeQuick intercooler, Level 10 trans & 9" converter, staged double-pumper, Bilstein shocks, Ultralite gauges, and the whole METCO catalog
Old Aug 15, 2002 | 04:32 PM
TanRchy's Avatar
Post
I hope you have a bullet proof drivetrain for thatclutch. Rear end, torque arm, tranny. That clutch grabs hard and will break **** if u race on slicks or get too agressive with it.
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Ringmaster72
Feb 25, 2015 03:15 PM
RichJ
Aug 11, 2002 10:14 PM
SABLT194
Aug 3, 2002 09:33 AM
