mass air sensor
Old Aug 20, 2003 | 10:16 PM
ws00ss's Avatar
mass air sensor
Is there a way to test mass air sensor to see if it is working besides autotap?
Old Aug 20, 2003 | 11:13 PM
cals400ex's Avatar
i don't think there is a good way to test it. i believe it responds to the pcm with a different frequency depending on how much current is needed to keep the wire at a certain temp. as more air enters, more current is needed to keep a constant temp. I know on an LT1 car you can disconnect it and it will go into speed density mode. I am not sure if this works on an LS1 or not. the only thing i can suggest is to clean it out with electrical contact cleaner or tuner cleaner spray from radioshack. if you have a friend with the same car, you could try swapping it out and see if there is a difference.
Old Aug 21, 2003 | 07:03 AM
teke184's Avatar
i was having car problems a couple weeks ago, i suspected the maf sensor (85mm ZO6 unit), so i unpluged it and the car started up fine and ran smooth.
so i know this works on the ls1 also...give it a try
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
NHSZ28
Jul 25, 2002 07:58 PM
