Major problem with LS1 help needed please
ok this is where i stand...
as stated above, i did a compression test and got only 30psi on the 5th cylinder.... now to figure out exactly what has happened....
There is no engine noise and i have great oil pressure. It simply feels just like i pulled off the plug wire to the 5th cylinder. Nothing more, nothing less.(besides the smoke at idle and some accelerations) I feel like if it was something major in the lower end there would be some kind of noise and the car would run like ***. The motor seems to be very smooth with just a small miss until put on a heavy load in a higher gear w/ low rpm.
i'm praying to find the problem when i pull the valve cover.
