Major problem with LS1 help needed please
Old Mar 22, 2007 | 08:30 AM
  #16
Kraest's Avatar
Retired
Originally Posted by ponykiller z28
ok this is where i stand...
as stated above, i did a compression test and got only 30psi on the 5th cylinder.... now to figure out exactly what has happened....
There is no engine noise and i have great oil pressure. It simply feels just like i pulled off the plug wire to the 5th cylinder. Nothing more, nothing less.(besides the smoke at idle and some accelerations) I feel like if it was something major in the lower end there would be some kind of noise and the car would run like ***. The motor seems to be very smooth with just a small miss until put on a heavy load in a higher gear w/ low rpm.
i'm praying to find the problem when i pull the valve cover.
Look a few posts up at what I said before. More than likely you blew the compression ring and ring landing = new piston and rings.
Old Aug 7, 2017 | 03:56 PM
  #17
Meko Ruffin's Avatar
Re: Major problem with LS1 help needed please
Did u ever figure this problem out ?
Old Aug 8, 2017 | 11:27 AM
  #18
Unfortunately, "ponykiller z28" has not signed into this site for more than 9 years.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jazsun
Dec 29, 2014 12:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
