LT's or shocks and springs????
Old Nov 28, 2003 | 06:31 PM
SHIZNIT's Avatar
I thought about lowering my car (shocks and springs) or going with long tubes. Which should I go with. For everyday driving. Thanks for info
Old Nov 28, 2003 | 07:09 PM
unvc92camarors's Avatar
either way you're losing ground clearance
Old Nov 28, 2003 | 08:46 PM
tailwindxr7's Avatar
I'd personally go for longtubes and then a set of shocks on the stock springs, but I'm not a fan of lowered cars (and I also live in a place with many hills and crappy roads.)
It's your call, really. Decide for yourself.
Old Nov 28, 2003 | 08:53 PM
Knowklew's Avatar
go with the LT's you will be happier
Old Nov 28, 2003 | 09:02 PM
tekker's Avatar
ownij! im doing both. just ordered my LT's and im gonna get some new shocks and lowering springs first quater '04.
and tailwindxr7 ive heard the lowered cars get slightly better control and hook better.. could be wrong.
/tek.
Old Nov 28, 2003 | 09:35 PM
Slightly better control, yes. Hook better, I doubt it.
Besides, shocks and other upgraded suspension/chassis components should be more than enough. You don't need lowering springs to make an excellent-handling car.
Old Nov 28, 2003 | 11:23 PM
tekker's Avatar
well i can tell you that i have stock 16" tires and my wheel wells look empty as ****. its like a truck thats had a 6" suspension lift and still riding on stock 22 or 25".. it doesnt look to grand.. and 1.2" in the front and 1.4" in the rear will fix alot of that..
and from what iv read a stiffer spring that lowers the cars center of gravity WILL help the car hook better off a launch.
/tek.
Old Nov 29, 2003 | 11:58 AM
mcflyz28's Avatar
Drop it and get the ride height you want that will limit you on header choices later, ground clearance will be a problem, I have none !!!, but it looks good .
Fastbird93
Jun 3, 2015 05:56 AM
KYWes
May 22, 2015 08:48 PM
BLK1997Z28
May 1, 2015 12:23 PM
Charged
Sep 25, 2002 09:28 AM
Pro Stock John
Aug 1, 2002 09:18 AM
