LT1 to LS1?
Old Mar 13, 2003 | 05:13 PM
  #46
Larnach's Avatar
The reason they move to the iron block is because its cheaper than the $6000 race block for big displacement without resleeving the cylinders.
The LS1 is plenty strong and is a very stiff cylinder case when compared to the LT1, apples to oranges, both are great engines though. Aluminium is a lot more brittle, but it is very stiff and doesn't distort near as much from heat soak.
Old Mar 15, 2003 | 09:34 AM
  #47
danziger's Avatar
Wink
I don't know if it is cost alone... You could go with Darton sleeves on the aluminum block like the big-cube motors do, but the head bolt seat strength would still be marginal. No one like lifted heads on a FI motor. I'm not saying the LS1 block itself isn't strong, but I think the LT1 bolck is a stronger and cheaper starting point for FI.
Old Mar 15, 2003 | 11:35 AM
  #48
Larnach's Avatar
Use studs not bolts.
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ddr698
Jan 9, 2015 10:05 AM
