Ls7 Ecm/pcm
Old Aug 17, 2007 | 12:20 PM
Ultra_Dog's Avatar
Ls7 Ecm/pcm
Can a regular (LS1) OBDII PCM be used for an LS7?
Old Aug 17, 2007 | 12:38 PM
SSpdDmon's Avatar
There are certain parts/things that need to be used....like reluctor rings and knock sensors. But, you can control an LS7 with an LS1 PCM. I think the reluctor on an LS1 crank has only 20-some teeth where as the one on the LS7 crank has 50-some teeth. You need the smaller one.
Old Aug 17, 2007 | 01:44 PM
Sparkz28ss's Avatar
the Ls1 pcm ia 24x and the ls7 pcm is 58x ...
you could also use the 07 and up Ls2 PCM as its 58x aswell...its plug and play with the LS7
also the 07 up LS2 pcm along with the LS7 Pcm are scaled to read boost pressure...
mrwz28
Jul 8, 2015 09:11 PM
TXNC5
Feb 23, 2005 04:01 PM
Gold_Rush
27
Feb 13, 2005 10:27 AM
BigTed187
Dec 3, 2003 02:14 PM
2QUIK6
Apr 27, 2003 07:19 PM
