LS7 cam
Old Jan 7, 2007 | 07:19 PM
moroso99's Avatar
LS7 cam
Got the LS7 motor in the garage, waitin for the 66 chevelle frame to be done, in the meantime, had a hotcam kit put into the LS7 along with a few other goodies, was wondering if anyone here knew if the stock LS7 cam would fit into a LS1 motor, I dont know that much about cams.
the LS7 stock cam is 15-mm (.591-inch) lift, will this fit? I want to put a cam in the LS1, and since the stock one was taken out of the LS7, I didnt want it to just sit on the shelf and not get any use.
Old Jan 7, 2007 | 10:16 PM
Sh4Dy's Avatar
It will fit, but the camshaft position sensor and cam wheel are located at different areas. So it will not work unless you change the front cover, cam sensor, extend the cam sensor wire and swap a and c on the connector.
Old Jan 8, 2007 | 01:21 PM
moroso99's Avatar
huh, well thats seems do-able, probably be easier just to get a cam thats made for the LS1
dfarr67
Apr 10, 2015 07:44 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
Bearmans
Dec 3, 2014 05:28 AM
