Ls6 intake
Old Feb 18, 2008 | 08:46 AM
kyle67camaro's Avatar
Ls6 intake
Ok so I put a ls6 intake on my 98 z28, but now my idle is all messed up and likes to rev up to about 3000 rpm's but always is different. I heard that if I reset my computer and drove it the compter would relearn the idle because of the more air flow of the ls6. I did that and have drove for over 300 miles and its still doing it. Any ideas or advise. I am thinking I might have missed the memo about having to get it tuned or something like that after doing this. I dont know, but I am open for advise. Thank you all so much.
Old Feb 18, 2008 | 09:21 AM
2000GTP's Avatar
Check over everything, make sure all of your connections are connected and tight. Sounds like you have a vacuum leak going on somewhere.
Old Feb 18, 2008 | 11:22 AM
Bayer-Z28's Avatar
Vacuum leak.. Check your brake booster line and stuff in the back of the intake.. PCV connections, etc.
And FWIW: the LS* computers relearn within seconds. It's not like the L98 OBD1 computers that needed a full drive cycle.
Old Feb 18, 2008 | 11:44 AM
2xLS1's Avatar
What did you do about the 98 coolant crossover tube under the intake? Did you also remove the green plastic pieces taped to the KS wiring harness?
Old Feb 18, 2008 | 03:11 PM
yes I put the coolant lines under the intake, but I dont remember anything about the green plastic pieces.
Old Feb 21, 2008 | 09:08 PM
Kwiksilverz28's Avatar
I did mine yesterday. No green plastic pieces on mine either.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
