LS3 heads Will they work
Old Aug 10, 2011 | 12:12 PM
  #16
Sparkz28ss's Avatar
Re: LS3 heads Will they work
Originally Posted by Marc 85Z28
First, look at the cost. Second, look closer at the cost - particularly all the additional parts necessary to run those heads. Finally, look at the results. NOBODY has had any real success with those heads on a 3.89 bore. They make power on par with ported stock castings.
The whole idea behind running an LS3 head (and their only redeeming value) on anything but an LS3 is the budget performance aspect. Once you have to pay nearly $3500 for a set of heads (price of heads, rocker, and dedicated intake) they aren't budget by any means and they had better perform along the lines of an AFR 210 or TFS 215. THEY DON'T. There's a lot of work in those heads for a substantial cost only to put you in the wrong direction - therefore it's a hack job. ALL the record setting stock bore engines run a cathedral port for a reason
I do not care about the cost. That's not what I'm taking about.
Ls3 small bore head
Flow Data w/3.900" Bore Plate
Lift Intake Exhaust
0.100 76 57
0.200 147 110
0.300 218 172
0.400 274 214
0.500 318 234
0.550 333 242
0.600 342 248
0.650 349 252
0.700 353 257
AFR 230cc runner for small bore...the 210s for a 4" bore is flowing just over 300cfm@.600
Old Aug 10, 2011 | 01:01 PM
  #17
Marc 85Z28's Avatar
Then what are you talking about? If you're comparing ONLY flow numbers, I'll make this my last reply to you as you obviously don't have either a clue or any firsthand experience. Flow numbers don't always translate into power. There is a lot more going on than just what the flowbench reports. I'll say it one last time in case you missed it... the cathedral port offerings are superior both in power and track times for the stock bore LS1, REGARDLESS of flowbench data.
Edit: A flowbench is like a dyno, it only shows part of the equation. I make 40rwhp and 160rwtq LESS than you at a similar weight, yet I've gone faster and quicker. It's what you don't see behind the dyno numbers that makes the difference.
Old Aug 12, 2011 | 06:40 AM
  #18
AL SS590 M6's Avatar
Moderator
And the dyno says that I make less HP and torque than Mark and run the numbers in my sig. + a smidge (haven't updated it lately) with as cast Dart heads. It's way more about combination and application of parts than raw test numbers.
parkers Z28
Mar 11, 2016 08:14 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
