LS1 Oil Pan Gasket...
Old Oct 11, 2007 | 11:18 PM
ruck0loc0's Avatar
My 2000 Camaro keeps leaking oil and people tell me its the oil pan gasket... is it possible to do it myself and if not about how much would it be to get a mechanic to fix it? Differential gasket needs to be replaced too, thanx!
Old Oct 12, 2007 | 04:50 AM
AL SS590 M6's Avatar
Moderator
The oil pangasket on the LS1 motor should never ever leak. It's an aluminum gasket with a rubber sealing ring.
You would have take out all the pan bolts, the 2 lower bellhousing bolts, and loosen the front cover to lower the pan. Then you could use lint free cloths to clean all the surfaces and bolt/torque everything back together. If you want to pull the pan completely then you have to secure the engine from above and lower the K-member.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
