LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
Old Sep 10, 2007 | 02:21 PM
Mike96z's Avatar
Alright, putting a 99 LS1 in my 96 camaro, now I heard that everything will work except for the Tachometer, in which you have to use an adapter for but I cannot find this adapter, what must I do to get the tach on my LT1 Guages to work with this LS1 engine?
Old Sep 10, 2007 | 02:38 PM
Mike96z's Avatar
nvm found it
http://www.dakotadigital.com/index.c...rod/prd127.htm
Old Sep 11, 2007 | 10:38 PM
RE AND CHERYL's Avatar
Don't waste your money on that. The main difference is the LS1 PCM only put out 2 pulses per revolution and not the 4 your LT1 tach needs. The PCM can be programed however to put out 4 pulses per revolution. Your gonna have to get the PCM programed anyway to eliminate various codes.
GO check out LS1TECH.COM in the conversions & Hybrids section. You will find more information on LS1 swaps than you will know what to do with.
Re'
Old Sep 11, 2007 | 11:05 PM
Mike96z's Avatar
im on ls1tech and i dont know how much itll cost to program it and who to get it done with. thanks
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
ro2207
Dec 4, 2014 06:18 PM
Rich_z28
Aug 29, 2002 10:44 PM
