ls1 misfire
Old Jan 31, 2006 | 10:36 PM
Daniel6718's Avatar
ls1 misfire
a freinds ls1 misfires whern cold outside and when low on gas???
what gives?
the code is for bank 7 coil, we put a new one and a new wire on it, so is it the injector?
Old Feb 1, 2006 | 06:11 AM
teke184's Avatar
Re: ls1 misfire
swap coil packs...there could be a faulty wire in the harness
Old Feb 1, 2006 | 11:01 AM
Daniel6718's Avatar
Re: ls1 misfire
code is for bank 7 coil, we put a new one(coil) and a new wire on it
Old Feb 1, 2006 | 02:46 PM
ATIProcharger's Avatar
Re: ls1 misfire
I had this happen, but it did not throw a code. Drove me nuts. Found a spark plug wire boot was split up the side a litte allowing it to arc with the insert. Check all the plug wires and boots.
Old Feb 1, 2006 | 05:23 PM
SFB767's Avatar
Question Re: ls1 misfire
What does a misfire feel like?
For the past month, when I'm at a light or idling, my car feels like it wants to stall out one minute, and the next it'll idle like a Lexus.
The RPM and oil pressure needles both stutter somewhat, but once I take off and go on my way, everthing's fine.
Jeff1904
Jun 5, 2016 05:00 PM
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
