LS1 max rpm
Old Sep 12, 2003 | 02:10 PM
1and4gen's Avatar
LS1 max rpm
Hello folks, Its been awile since posting anthing.
I am adjusting shift points at WOT for my a4 (m6 rteplies ok) and like to know what rpm is the best......dont know th power band on the 02 LS1. Stock with the 373 rear was shifting around 5500...accordin to tack. thks
Old Sep 12, 2003 | 02:26 PM
SSCamaro99_3's Avatar
Fuel shuts off at 6250. I have my light set at 5700 to give me shifts of around 6000-6100.
Old Sep 12, 2003 | 02:28 PM
Constrictor98TA's Avatar
A stock LS1 has a rev limiter of 6200 RPM. You should NOT raise it any higher than that without upgrading your valve train.
People with beefed up valvetrains and bottom ends have red lines over 7000 RPM.
You should never trust your tach as a representation of where it shifts. Our tachs are slow and do not show the correct RPM at WOT, especially in the 1-2 shift, and even in the 2-3 shift.
More than likely, your shift points are as good as they are going to get with stock heads and cam, so I would leave them alone. If you start to upgrade your engine with a new cam and heads and such, you will want to get your dyno sheet and adjust your shift point to about 100 RPM past your HP peak.
Old Sep 12, 2003 | 09:21 PM
1and4gen's Avatar
Constictor.....
yea i understand what your saying, but after changing gears from stock (323) to 373 and using th HPPIII programmer it sure seems to prematurely shift into 2nd (tack shows 5500) but throws down some serious rubber hittng 2nd. I have raised it 450 rpm for the 1/2 shift (tach showing 6grand) but am wondering if I am not helping matters (yea i know track times are what i need, but not practical). yea, i did raise the rev limit to 6500 so as not to code the ECU.
any more comments?
allen
Old Sep 13, 2003 | 03:54 AM
mr_muff's Avatar
put the rev limiter down right away. i would not touch it. if anything i would put it to 6200 in stead of 6250. i had to redo my top end because i mechanically over-revved it to about 6400-6500. it is not the funnest job in the world to do in the garage when you are trying to pay bills for school and then all the new stuff i had to buy to redo the valvetrain.
i highly recomend putting the rev-limiter down to 6200.
Old Sep 13, 2003 | 09:02 AM
ULTIMTEORANGESS's Avatar
ill third this and say put your stock revlimiter back in.youre not making more power anyway by raising it with a stock valvetrain even with gears.
Old Sep 13, 2003 | 10:33 AM
1and4gen's Avatar
thanks guys......ill go back to stock with stock shift points also. any comments on increasing shift firmness?
thks
rideordie
Nov 5, 2019 04:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
NewsBot
May 29, 2015 01:40 PM
