Are LS1 and LT1 injectors the same?
Old Dec 24, 2004 | 04:13 PM
Mike94ZLT1's Avatar
Hey guys, I need bigger injectors, and I have a friend with 42 lb SVO's that I would like to use, do I need to modify anything to make them fit, aside from recalibrating the computer? Thanks!
Old Dec 24, 2004 | 05:49 PM
AL SS590 M6's Avatar
Moderator
Re: Are LS1 and LT1 injectors the same?
I don't think so.
Old Dec 25, 2004 | 01:28 PM
MISOMWS6's Avatar
No they are not the same. They are rated at a diffrent fuel pressure. LS1's pressure is higher and run at 4bar and the LT1's run at 3bar. I wish I had some more detailed info for you but i'm quoting an article in my GMHT january issue. TTT for ya. Hopefully someone has some more specific info yor you.....
Old Dec 26, 2004 | 03:12 AM
Drew778/94Z's Avatar
You can use the 42 lber with the right tuning, they would be more like 46-48 lbs for LS-1 fuel pressure.
I'm using 30 SVO's just fine, go to LS-1tech for some formulas
Old Dec 26, 2004 | 12:15 PM
Mike94ZLT1's Avatar
thanks for the info guys!
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jul 4, 2005 05:00 PM
