Are LS1 lifters fickle creatures?
Old Oct 29, 2004 | 12:23 AM
Timberwolf's Avatar
Got to thinking about it...
my valve train seems a bit noisy. and considering it's stock lifters, aftermarket pushrods and springs and stock rockers, I wouldn't expect any more noise then stock really.
Also, when I swapped out the Yank converter for the Vigilante a few weeks ago, we turned the motor over by hand a few times to get to all the bolts. When all was said and done, we fired it up and there was a lifter or two tapping. Apparently it had bled down. But the thing was, it took nearly 3 minutes to pump back up. What would cause this?
Is there a possibility I have some bad lifters? Also, how do I go about doing a pushrod length check to see if I need longer or shorter pushrods?
Old Oct 29, 2004 | 02:37 AM
94ZRiCeKiLr's Avatar
Re: Are LS1 lifters fickle creatures?
the LS1 in general is a bit more vocal than your average hydraulic roller motor...
i don't think i've ever heard an LS1 that didn't make one or another valvetrain noise from time to time.
unless you hear something glaringly obvious or extremely abnormal, i woudln't worry too much.
Old Oct 29, 2004 | 07:17 AM
teke184's Avatar
when i swapped my valve springs a few weeks ago, the lifters bleed down apparently, and it took a good 2-3 min for them to quiet down again.
it suprised me
but then again, i think i have a few bad lifters as well...so who knows if my experience was any different than yours
Old Oct 29, 2004 | 12:33 PM
MikeyG's Avatar
Yeah most people report alot more valvetrain noise after a cam and/or header install. I wouldn't worry about it.
Old Oct 29, 2004 | 08:27 PM
AL SS590 M6's Avatar
Moderator
The valve train is a little more noticeable on the LS1 because aluminum doesn't dampen the noises like cast iron.
I really can't say on the stock lifters with heavier valve springs because I went with Comp "r"s which are really touchy about preload so they don't play well with non-adjustable rockers.
Ericksd
Jan 20, 2016 06:07 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
