LS1 engine specs?
LS1 engine specs?
A little help, please. I need to know the following about the LS1 in the F-body.
bore and stroke
head gasket thickness and bore diameter
cylinder head volume
piston crown volume
rod length
Thanks.
Rich Krause
bore and stroke
piston crown volume
rod length
Thanks.
Rich Krause
Re: LS1 engine specs?
bore and stroke
piston crown volume
rod length
Thanks.
Rich Krause
bore and stroke
piston crown volume
rod length
Thanks.
Rich Krause
stroke 3.622 in
gasket thickness and bore( don't remember and not at the shop to measure one)
cylinder head volume - combustion chamber 66.67cc, intake port 200cc, exhaust port 70cc
pistons- hypereutectic flat tops(no valve reliefs)
rods-6.1 in
Re: Re: LS1 engine specs?
Originally posted by Demon SS
bore 3.898 in
stroke 3.622 in
rods-6.1 in
bore 3.898 in
stroke 3.622 in
rods-6.1 in
Rich Krause
Brandon Wittmer
Dec 20, 2014 09:51 PM
ChrisFrez
Nov 23, 2014 10:33 AM
jrp4uc
Jun 19, 2002 06:20 PM
