LS1 Carbon Fiber Lid
Old Feb 17, 2007 | 08:57 PM
RacerChuck's Avatar
I just got an SLP Lid from Thunder Racing.
The insisited that I also purchase the small filter that has about a 1" Dia tube on the side and is a circular K&N about 3" in Diameter.
The Existing and New Lid both have a hole on the right side but the existing one has something electronic that I guess I'll have to change over as it's held in place with a rubber grommet (this is even mentioned in the instructions)
Where does the small K & N Filter Go?
Old Feb 18, 2007 | 05:06 AM
Lunch Box's Avatar
The small K&N filter goes on the line to the AIR pump (Hose that comes off the driver's side (if I remember right) of the factory lid) if your lid doesn't have the nipple for it
You'll likely have to zap-strap the line up out of the way
hope this helps
Old Feb 18, 2007 | 09:05 AM
AL SS590 M6's Avatar
Moderator
The small hole with the electronics in it is the Incoming Air Temperature sensor commonly refered to as the IAT. Carefully wiggle that out of it's gromment and install the grommet and sensor into the new lid.
Now on the side of your old lid is a 3/4" hose that goes off under the front corner of the car. That's the intake hose for your Air Induction Reaction pump commonly refered to as AIR pump. This hose is where the little filter goes then you can situate and zip tie it where it's out of the way and looks ok.
Old Feb 20, 2007 | 12:55 PM
Blk02Z28's Avatar
i cut about 6-8 inches of that hose off and it worked fin e and looked pretty good 2. that way dont have 2 use zip ties. just a thought.
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
