LS1 camshaft help
Old Feb 20, 2012 | 01:34 AM
jrips69's Avatar
Cool LS1 camshaft help
Hey Camaro lovers... I have a 2002 Camaro z28 with 107xxx miles all stock... I'm looking to buy a performance cam shaft but idk I heard they go by numbers which one should I get if I have a all stock Camaro.... I'm trying to give it that better rpm... Or wt ever it helps u on... I just don't know things like this... Thanks
Old Feb 20, 2012 | 07:11 AM
rv93's Avatar
Re: Ls1 cam shaft help
swapping cams is not a good first upgrade. if you have an auto transmission, your first upgrade should be a higher stall torque converter. then regardless of the transmission, a different rear end ratio would help. then you need to take care of the exhaust. its a bit of a bottleneck. then you can start looking at cams.
Old Feb 20, 2012 | 08:35 AM
Probably a good topic for LS1 Based Engine Tech. I'll move your thread there.
Old Feb 20, 2012 | 12:56 PM
WhiteHawk's Avatar
Re: LS1 camshaft help
I always like the 224/224/ .581/.581 114+4 on a sock setup. Or if you want really mild get an LPE GT2-3 (207/220) and you won't even have to tune it. You will need to do springs with whatever cam you pick, though - I wouldn't trust 100,000 mile stockers for any amount of lift past stock.
-Geoff
Old Feb 21, 2012 | 01:02 AM
jrips69's Avatar
Alright... Wt should I do to the trans... It's a automatic. And I have 1200$
Old Feb 21, 2012 | 11:43 AM
whitdog54's Avatar
buy a used yank ss3600 stall converter. (like $600)
tranny cooler (100ish)
With install, you're right at $1000 then your probably gonna want gears (another 200ish), then sticky tires. 1200 isnt gonna cut it.
for 1200 id get ported and polished TB (ebay, POTZ performance, send your stocker back as core, cost you like $40)
slp lid(80)
catback exhaust (300-500ish)
install (300)
tune:
TunedByFrost.com - Professional Tuning For Your LSx Powered Car or Truck
some used 555Rs in the classifieds (like 250) you're gonna need drag radials.
start saving again for longtubes, ORY, stall, and maybe cam/heads/nitrous, or turbo haha and a dynotune.
modding isnt cheap, especially if you cant do install or tuning yourself.
Old Feb 21, 2012 | 06:06 PM
jrips69's Avatar
What I just put some headers there BBK long tube
Old Feb 22, 2012 | 11:26 AM
whitdog54's Avatar
im grabbing bbk LT and ORY once this refund comes in. such a good deal
Old Feb 22, 2012 | 02:41 PM
jrips69's Avatar
Yea I just got BBk headers with the y-pipe for 400$$$$ at jegs.com
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
