LQ4 swap in. Any tips from previous users?
Old 04-07-2012, 12:11 PM
omega552003's Avatar
Picked up a LQ4 engine and LM4/L59 PCM today for building an LSX engine for my 97. when it does go in it'll be more appropriate for an f-body. Planning on putting L92 heads and L76 intake.
I'd like to know what major hurddles i should expect?
Also is it a good idea to rebuild the engine for ground up or is the bottom end ok for 400hp? What would be a decent street/strip cam?
omega552003 is offline
Old 04-09-2012, 03:53 PM
raulz28's Avatar
Location: 5 minutes from the warzone in mexico(south texas)
Re: LQ4 swap in. Any tips from previous users?
The bottom end can easily handle 400hp. What I would do first is raise the compression up some since the LQ4 cam with a 9.5:1 CR I would try and get it to somewhere around 10.3:1 probably higher. As for a cam one in the 228/230 range should be pretty gkoood.
raulz28 is offline
Old 04-09-2012, 06:54 PM
here's the CompCam calculator, I know i'll never see those numbers but it gives me a good idea of what the theoretical max is. (its really close for my lt1 /w hotcam)
I did see a cam close to those durations, but its listing it as a rougher idle and I would be using this care for street more than strip.
Click to view this image.
Old 04-09-2012, 08:33 PM
Need4Camaro's Avatar
Actually it is VERY possible to see those numbers. L92 Heads, Raised Compression, and a Cam are absolutely no joke on the 6.0L engines... They become down right monsters for pretty much pocket change.
Need4Camaro is offline
Victor Lamb
08-26-2017 02:52 PM
06-06-2015 08:27 AM
4586
Parts Wanted
03-17-2015 11:24 PM
rjc1629
01-27-2015 10:46 AM
cmdeshon
12-27-2014 10:06 AM
Quick Reply: LQ4 swap in. Any tips from previous users?
