Lowering a car with LongTubes
Old Sep 6, 2003 | 04:54 PM
Black01_Z's Avatar
Okay I have LTs and want to start making my car handle a little better. Im thinking of doing swaybars and springs first and eventually shocks funds permitting. Now the problem with springs would be is that they would lower my car about 1-2 inches depending on the setup. Would I be able to clear with LongTubes. Anyone that has a lowered car with LongTubes please let me know any problesm that came up.
Old Sep 6, 2003 | 05:28 PM
mr_muff's Avatar
from what i have read you should be fine with the hooker long tubes. i will probably be getting a set of those and my car is lowered 2 inches and i hope it is gunna be ok. what kin of springs were you planning on getting? i have suspension techniques 1.5 in front 2 in the back. i must say thought it does look a lot lower than 2 inches in the back when it is side by side my buddys 99 SS that has not been lowered.
Old Sep 6, 2003 | 05:31 PM
02CamaroZ28's Avatar
I have the sportlines which are a 1.8 inch drop and also run the FLP longtubes. I drive around with no trouble whatsoever. Today was my first attempt with the LT on going over a speed bump, I have very slight scrape for abour an inch and went over fine. Im sure if you get less of a drop (prokit) you could get around even easier.
Good luck,
Mark
Old Sep 7, 2003 | 12:52 AM
redsscamaroboy's Avatar
Hooker long tubes and Eibach Prokit,no troubles driving around town,but be carefull on speed bumps(nice and slow). They touch ,but only sometimes.
Hope this makes you feel a little better.
Dave
Old Sep 8, 2003 | 02:43 PM
CODE4LS1's Avatar
I have the Eibach Prokit on my 2000 SS w/SLP Longtubes, and there are no probs driving around, but like previous posts, they do tend to touch a little bit on speed bumps, but nothing to worry about
Old Sep 8, 2003 | 10:44 PM
CamaroBoy96Z28's Avatar
I have very little problem with speed bumps...but I'm not lowered. The only thing that scrapes is the y-pipe where it dips a little right after the driver's side primary. Its not really the LTs themselves that scrape, its the y-pipe. You should be ok but still avoid those speed bumps regardless.
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
USAirman93
Nov 24, 2014 03:37 PM
