Lowering a car with LongTubes
Okay I have LTs and want to start making my car handle a little better. Im thinking of doing swaybars and springs first and eventually shocks funds permitting. Now the problem with springs would be is that they would lower my car about 1-2 inches depending on the setup. Would I be able to clear with LongTubes. Anyone that has a lowered car with LongTubes please let me know any problesm that came up.
from what i have read you should be fine with the hooker long tubes. i will probably be getting a set of those and my car is lowered 2 inches and i hope it is gunna be ok. what kin of springs were you planning on getting? i have suspension techniques 1.5 in front 2 in the back. i must say thought it does look a lot lower than 2 inches in the back when it is side by side my buddys 99 SS that has not been lowered.
I have the sportlines which are a 1.8 inch drop and also run the FLP longtubes. I drive around with no trouble whatsoever. Today was my first attempt with the LT on going over a speed bump, I have very slight scrape for abour an inch and went over fine. Im sure if you get less of a drop (prokit) you could get around even easier.
Good luck,
Mark
Good luck,
Mark
I have very little problem with speed bumps...but I'm not lowered.
The only thing that scrapes is the y-pipe where it dips a little right after the driver's side primary. Its not really the LTs themselves that scrape, its the y-pipe. You should be ok but still avoid those speed bumps regardless.
