Lower Control Arms... Which ones do you guys think are the best for the price?
Let me know what you guys are running for LCA's, thanks. Also, do you think a Transmission cooler is worth it?
--Michael
'01 Camaro SS A4
Mods Include:
Superior 3.73 Gears, Jet Chip Racing Chip, K&N Air Filter, Free Ram Air Cut-out, Granatelli MAF, Whisper Induction Lid, Corsa Cat-back Exhaust, Jet PCM Controller--Calibrates for my gears, Auburn Carrier, Hypertech 160 Degree Thermostat, SLP Strut Tower Brace, Sub Frame Connectors, Throttle Body Bypass, Powerslot Slotted Rotors, Hawk Performance Brake Pads.
Best 1/4: 13.192 @ 106.38MPH w/2.086 60' on GoodYear Eagle F1 tires.
Recent 1/4 run on 4/10/02: 13.502 with a 2.367 60' on 275x40ZR17 Dunlop SP sports, without the 160 thermostat, STB, SFC, or TB Bypass--With Some DR's, maybe run a 12.8, or 12.7? Fingers crossed. Headers coming soon.
See "Cammie" at http://members.cardomain.com/ozorowsky
--Michael
'01 Camaro SS A4
Mods Include:
BMR's are good. I personally have MAC boxed lower control arms just because I bought them off of this site along with a MAC panhard for $115 bucks. It was a good deal, I just had to pick them up - it was a local sale.
btw, the ones I have work great.
Milo
Milo
I've pretty much got an entire LCA, Panhard, Torque Arm and safety loop setup from Spohn Performance. I'm adding a driveshaft too, since my aluminum one exploded Friday night!
Anyway, I really like the setup. The LCA's are tubular and not boxed, but they surprisingly look very good on the car.
Steve Dertien
Grand Rapids, MI
2002 TransAm WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Steve Dertien
Grand Rapids, MI
2002 TransAm WS6
Hey guys, ok, what does chrome/moly mean? And what to go with? poly/poly or rubber/poly? Thanks. Please simplify this for me guys. I'm no expert at this stuff. Thanks again.
--Michael
'01 Camaro SS A4
Mods Include:
--Michael
'01 Camaro SS A4
Mods Include:
What are some web sites talking about coming with grease fittings? Do you have to grease these regularly? Thanks.
--Michael
'01 Camaro SS A4
Mods Include:
--Michael
'01 Camaro SS A4
Mods Include:
<font face="Verdana, Arial" size="2">Originally posted by Michael Ozorowsky:
</font>
</font>
Rubber/Poly and Poly/Poly refer to the bushings in each end. You can get one of each on either end or both the same. The rubber poly is popular because it's a bit quieter than poly on both ends. On mine I have poly on both sides. You only hear the car squeak in parking lots.
My LCA's do come with grease fittings. You do not have to service them regularly. Several thousand miles maybe before you can regrease them. With my poly bushings I use a silicone grease, not a standard chassis lube like you would imagine that you'd put in there. I greased mine up recently and the parking lot squeaks actually went away. So it does have some effect on the sound and ride quality.
In general most of the LCA's are going to be extremely similar in capability. There's nothing magical about a BMR vs a Spohn at the end of the day. Just comes down to your preference.
Grand Rapids, MI
2002 WS6
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
I have the Spohn setup and they are awesome. However, I have not had another brand to compare with, but they are still a worthwhile suspension mod.
http://camaroz28.cardomain.com/id/whitedeathls1
1999 Sebring Silver Metallic Z28, M6 T-tops
Cosmetic Mods: GM SS Hood, 18" Y2K Chrome Corvette rims on Kumho Ecsta 712s in 275/35/18ZR, Corvette FRL covers (More to come!...)
HP Mods: Borla Catback, Granatelli MAF, Whisper lid with K&N, Free Ram Air, Superior 4.10s w/Ratech Crush Collar Kit, TA girdle w/stud kit, HPP3 w/160 t-stat, MMS ported TB, EGR and TB coolant bypass, ASP crank & Alternator pulleys
Suspension Mods: KBDD SFCs, Spohn LCAs & Adjustable PHR, Addco 32MM front and 1LE rear sway bars, BMR STB, Eibach Pro-kit
Extras: B&M Ripper shifter with RK Sport Satin Finish shift ****, Mobil 1 filler cap.
320rwp, 325 max torque on MMS Dyno jet!
R.I.P. 1998 Z28, 1/23/2002
Jan 23, 2015 01:13 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
