low oil light, not low on oil?
Old 02-13-2010, 07:22 PM
TA6.66LITRE's Avatar
change oil light came on 300 miles after I did oil change. Drove with it on because it doesn't know when I need to change oil. Sometime after that the low oil light came on, but the oil is not low. What is causing this, what can I do, should I worry about it?
My car does run rich if that makes any difference becuase it has an old cat converter and has a bad rear o2 sensor
2000 a4 z28 112k
thanks
TA6.66LITRE is offline
Old 02-13-2010, 08:07 PM
johnny6's Avatar
On the passenger's side of the oil pan there's a sensor that's plugged in, that's the oil level sensor. Jack the car up and see if what shape it's in, could be loose, dirty or faulty but if the oil level is fine i wouldn't worry about it but keep an eye on the oil level every once in a while just in case. As far as the change oil light, it probably needs to be reset and i forgot how to do it I think one of the ways is pressing the gas pedal all the way down 4 times with the ignition on and it should reset it.
johnny6 is offline
Old 02-13-2010, 08:25 PM
thank you
Old 02-14-2010, 12:04 AM
RedHottG2's Avatar
Whenever you change your oil you have to reset the gauge or the light will come on.
Turn the key,(not starting the car) hold the trip meter button down for 10 seconds.
RedHottG2 is offline
HectorM52
07-30-2017 11:46 AM
01-23-2015 01:13 PM
NorthPoleDev
12-31-2014 03:20 PM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: low oil light, not low on oil?
