Loose starter bolts?
Old Sep 10, 2007 | 12:37 AM
mmmchickenboy's Avatar
So it's been over a year since I sold my T/A.. but I am curious: Has anyone else encountered loose starter bolts? Resulting in a broken starter and block, like me?
I think the clutch was replaced before I bought the car and they just weren't tightened/lock tighted. I was at a gas station and went to leave and it made a bad noise when I tried to start, tried to start again and it was still goofed up. I got it started, went home (I was over an hour from home at the time) and checked it out when I got home. The small ear on the starter was broken and the outer bolt boss on the block broke out, about 1/4 of it. Put a new starter on and A LOT of red thread locker and it was fine from then on. But damn, how much would that suck to have to get a NEW ENGINE because some idiot didn't tighten the bolts? Could that even be repaired? I called a few places to see if they could weld it, redrill + tap, but they pretty much said no.
All in all this is a pretty worthless thread but whatever, I'm bored, and maybe it'll save someone some grief someday.
Old Sep 10, 2007 | 08:23 AM
AL SS590 M6's Avatar
Moderator
The starter bolts don't require Loctite but the torque spec is 37 lbft, and unless you use a torque wrench how do you know? I've had mine off a half a dozen times and never had it be loose.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 3, 2015 07:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
thenewkid
Nov 18, 2014 12:57 PM
