looking for some easy mods
Old Mar 12, 2010 | 06:34 PM
JFH's Avatar
JFH
I have a 98 ls1 car it only has a couple of mods on it. I ran it at the track last weekend and it ran good it ran a 8.33 at 86 mph. It has a cold air intake, underdrive, programmer, and a off road y pipe no converters with a 3" cat back. What are some of the free mods that i can do to help it perform a little better. I was going to try and port the mass air this weekend. Does it help much to block the coolant from going into the throtle body? Thanx for any help or sugestions
Old Mar 13, 2010 | 12:59 AM
henryz28's Avatar
I would get some headers and a tune, the little things like throttle body bypass and porting the MAF are not going to help much.
Old Mar 13, 2010 | 12:19 PM
bluz28's Avatar
If you car still has the EGR on it you could do the "egr mod" or buy a block off kit and expandable plug to put in the egr port on the intake. Port the TB, coolant bypass, and FRA .
Old Mar 13, 2010 | 12:21 PM
30th6's Avatar
do the bump stop mod to,like said above they wont help like new parts will but every little bit helps.
Old Mar 14, 2010 | 08:43 AM
AL SS590 M6's Avatar
Moderator
LEAVE THE MAF ALONE. The MAF is very sensitive and screwing with it will likely cause reverse results. Again incase you didn't hear me the first time. Leave the MAF alone it's fine in it's stock form.
Ported TB..........ok
EGR bobbit or complete removal.............ok
Throttle blade bump stop mod..................ok
Weight removal.....................great mod
TB coolant bypass...............good to keep TB heat soak down.
Old Mar 14, 2010 | 12:08 PM
JFH's Avatar
JFH
what is the bump stop that you are talking about? I am not that familiar with the newer cars still old school i guess. I didnt do the mass air. my car has some weight reduction a tubular k member with chrome moly a frames. thanx for all of the suggestions so far
Old Mar 14, 2010 | 01:25 PM
bluz28's Avatar
Thumbs up
Yes I totally agree, leave it alone!
Old Mar 14, 2010 | 02:36 PM
30th6's Avatar
you gring down the bumpstop on your throttle body so the blade opens all the way.search it for comlete details.
Old Mar 18, 2010 | 08:59 AM
JFH's Avatar
JFH
Thanks for all of your help
Old Mar 18, 2010 | 10:37 AM
Kraest's Avatar
Retired
What kind of programmer???
Old Mar 19, 2010 | 08:50 AM
JFH's Avatar
JFH
hypertech 3
Old Mar 19, 2010 | 09:48 AM
Kraest's Avatar
Retired
Hypertech is garbage -- it's shown to actually make your car SLOWER - remove that and it'll be faster.
Old Mar 19, 2010 | 01:20 PM
WhiteHawk's Avatar
Did you cut away the rad support cover to expose the entire air cleaner? Also, I assume by CAI that you mean Airlid?
-Geoff
Old Mar 22, 2010 | 07:01 PM
JFH's Avatar
JFH
If i bought another programmer which 1 is better i dont know any place around here that programs them. And I have everything cut out on the cold air i put the slp lid and the metal peice in front of the rad. the guy that i bought the car from had removed the part between the filter and the support. Thanx again for your help
Old Mar 22, 2010 | 09:23 PM
johnny6's Avatar
Send your PCM to madz28, most aftermarket programmers are useless.
http://www.madz28.com/
Mikes 1994 z28
Oct 10, 2015 07:55 AM
CARiD
Sep 30, 2015 05:44 AM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
