LM7 build up?
LS6 cam is kinda weak for NA 6.0L, but will work decent on boost. Make sure you get a 2002+ LS6 cam if you get one. That motor already comes with lower compression (9.6:1), so it's begging for boost
EDIT: If a forged bottom end is in order, I was thinking 4.000 inch crank and forged alum full dish pistons...for ~9.0:1 compression ratio.
These are all long-term plans, to be installed in an 98-02 fbody, possibly with a STS turbo kit or comparable alternative, AND all while still being able to pass emission.
If boost is on the menu, keep the compression ratio the same and get a forged bottom end for insurance? What would be a better alternative for the LS6 cam? If budget permits...P&P the heads?
I doubt you can run the STS kit and pass emissions or visual inspection with a turbo sitting under your rear bumper. The STS isn't worth a **** IMO anyway.
If you need to pass emissions, I'd just run the LS6 cam, leave the heads alone, and get a Procharger D1SC kit and see how you like it
You should be around 450-480 rwhp with no problem at all.Mike
Depends on how much boost you want.... you don't NEED a forged bottom end unless you're throwing a ton of boost at it. As long as you have good injectors/pump, you should be able to run around 8-10psi no problem on the stock LQ9 compression.
Mike
I will look into a Procharger kit. Thanks.
I picked up the motor today...I verified that its a complete 6.0 liter LQ4 with aluminum 317 heads...all for $500+taxes. I bought an engine stand, waiting on a buddy to borrow a cherry picker to get it off the truck. I'm excited to start the project.
New recipe.
New recipe:
Stock crank, polished and balanced
Eagle I Beams
Mahle Pro Packs
Bore/Hone the block
Dart 225cc Stage 1 heads
Custom grind cam
LS6 Intake
1 7/8ths Headers
Goal: 500 rwhp.
Eagle I Beams
Mahle Pro Packs
Bore/Hone the block
Custom grind cam
LS6 Intake
1 7/8ths Headers
Goal: 500 rwhp.
