LM7 build up?
LM7 build up?
If I could pick up an 04 LM7 (intake to oil pan) for ~$400, would that be a desirable engine to mod? I know is a 5.3 liter iron block and heads. Looking for either head/cam swap or supercharger/turbocharger. Thanks for the help.
I guess I will look for a 6.0 liter. I only ask cause the junkyard near me has a couple LM7's sitting around. I never find LS1's and I hardly find 93-97 Camaro's there, much less a Z28. I want to get a long block on a stand for a build up for an F-body, but I don't want to spend alot of money on the block. Whenever I see a long block for sale, its always in IL, WI, or somewhere else really far away.
You could get it, nothing wrong with it...You're just a little low on displacement...With boost it would be cool i think...Uses the same stroke as the LS1 at 3.622, with a slightly less bore...You could do an overbore if you wanted to, or stroke it...
and then some good heads and a cam on there, and you've got yourself a good motor...
Do you think $400 is a good deal. I have heard the truck heads are good for boost, but I'm not sure about the block. I know the cr of the LM7 is lower than an LS1. I will look into the cost to have the block bored. I just wanted to ask some questions so that I wouldn't be wasting my time with that motor.
Two completely different bore/strokes, though. The LS is going to be 3.905" x 4.00" and the LT is going to be 4.03" x 3.75".
If you're still serious about using the LM7 you can bore it and get a 3.9" bore out of it and make it into a 5.7L or even a 383. However, if you were looking into doing machine work to a block, I'd start out with a LQ9 or LQ4 block and make it into a 408. You can build them to handle power, but why start with less cubes? You could throw some aftermarket forged pistons/rods in a 346 LS1 to handle a ton of boost without worry about much.
Mike
That's what I really want to do. Need to find a good deal on an LS1.
NEW Question.
$600 for an complete LQ4...worth it?
I went back to the junkyard, and discovered one of the engines I thought was a LM7 is actually an LQ4. I believe its an 00', its complete and it looks in good shape.
As said before, I want to get a motor on a stand and build it up. Is this a good platform?
Yes , that is a 6 liter truck engine if I remember correctly . If that is a running engine I would say that is a pretty good deal . You could try to bargain on the price, who knows... you might get a real good deal !
