Leaves are getting into my vents. Have a lcicking noise when my vent motor is on.Help
Old Oct 21, 2003 | 04:18 PM
Flare65's Avatar
From: Welcome to Chicago. Get out while you are still alive.
Since my car sits under a tree at my house (No Garage) I get a lot of leaves and those little helicopter spinner things that fall off the branches on onto my car. A few of these have worked themselves into my vent and now when I run my vent motor I hear them moving aound in the dash.
A few years ago the dealer cleaned the leaves out for me, but how they want money to do it and I don't want to drop 100.00 on labor to do it. I think he opened a panel under the glovebox. I remember that it didn't take him too long to do it
Out of cuiriosity, I pulled the panel out below the dash and saw what looked to be the box where the air would pass through. Is this what I need to open up to clear out the leaves? Its surounded by wires and what looks to be the radio antenna line.
Could someone give me some tips on how to open this up? The car is a 01 Camaro.
Thanks!
Old Oct 21, 2003 | 05:31 PM
BandDirector Blk98ZM6's Avatar
It's a simple fix, so don't pay anyone to do it.
You're correct, pull the panel off under the glove box. On the right side, you'll see a round cover that has 3 screws up at the very top...there's also a 2 or 3 prong plug going to it. That is the actual fan motor assembly. Remove the 3 screws, unplug the motor and it will drop right out. The leaves are usually stuck in the fan motor. Once it's out, you'll see them immediately, and just pull them out and put it all back together. It'll take about 10-15 mins for the entire job.
Good luck!
HectorM52
Jul 30, 2017 11:46 AM
jmadoll
May 27, 2015 07:13 PM
Fatdog2
Feb 12, 2015 12:24 PM
jb4xx
Feb 2, 2015 10:00 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
