l92 heads and 427 stroker
Old Mar 21, 2007 | 06:55 AM
Travis.Bill's Avatar
Question l92 heads and 427 stroker
I was wondering what kind on power i could be expecting at the flywheel I am in the process of building an engine . I have ported l92 heads and a 6.0 liter iron block with a 4.125 stroke and a 4.040 bore I think the cubic inches will be somewhere close to 427. the compression will be 11.5to1. rod length is 6.125. also any cam suggestions ie. solid vs hydraulic. will be appreciated. This is going in a 99SS. thank you.
Old Mar 21, 2007 | 08:47 AM
AL SS590 M6's Avatar
Moderator
A guy on LS2.com just posted up 527 rwhp and 500 rwtq on a 415 cube L92 headed LS2.
Old Mar 22, 2007 | 05:35 AM
Do you know if that was with ported heads. Thanks for the info.
Old Mar 22, 2007 | 08:42 AM
Kraest's Avatar
Retired
I wouldn't expect anything less than 650 crank horsepower from that setup if it's matched correctly.
Old Mar 22, 2007 | 08:36 PM
Moderator
Stock l92s
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BIGCOWL-IMP
Feb 7, 2015 06:10 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
