l92 heads and 427 stroker
I was wondering what kind on power i could be expecting at the flywheel I am in the process of building an engine . I have ported l92 heads and a 6.0 liter iron block with a 4.125 stroke and a 4.040 bore I think the cubic inches will be somewhere close to 427. the compression will be 11.5to1. rod length is 6.125. also any cam suggestions ie. solid vs hydraulic. will be appreciated. This is going in a 99SS. thank you.
