Just dynoed for the first time... Tell me what you think
Old Jan 28, 2003 | 12:44 AM
  #16
danno02SS's Avatar
The DA was -1300 ft.
Where the hell are you running? Death Valley?
Old Jan 28, 2003 | 02:19 AM
  #17
psychocabbage's Avatar
Originally posted by AL SS590 M6
Mark,
Don't ever be disappointed by dyno number comparisons.
Point in case....................check my sig.
I'll bet there are a lot of cars out there that dyno more than my measley 312hp that don't run the numbers that I do at the track!!!!
Dyno numbers are only good to compare your car before and after mods.
how repeatable are those numbers?
Old Jan 28, 2003 | 02:23 AM
  #18
Originally posted by mark896
No worries. It seemed that since you decided to go into detail about my signature (with the red highlight and everything), maybe I should go into even more detail about the specifics of it. Thanks though, I guess.
its kewl.. i was going to do it in blue
but just wanted to type less. red was shorter..
I often disect sigs.. i feel it helps new members and lurkers understand that some mods arent really mods.. just a way of spreading more information
Old Jan 28, 2003 | 11:53 AM
  #19
ssvegas's Avatar
i love the:
SS floor mats mod
Old Jan 29, 2003 | 12:09 AM
  #20
AL SS590 M6's Avatar
Moderator
If I were to go to the track again when the DA was -1300 I would run the same numbers. If it were 80°, 80 humid, and 29.9 baro I'd run 12.50s or there abouts. Weather conditions play a huge role in the making of HP at the track. Whereas dyno readings are corrected to a set of standards.
I go to the track a lot, 350+ passes in 3 years. (and that's on the origional 4L60E) And I document everything. I take a weather station with me. I can pull in, get the weather station out and tell you within a half of a tenth what I will run. Most days I run within a few hundredths of my dial.
Old Jan 29, 2003 | 12:14 AM
  #21
Moderator
Density Altitude is a calculated altitude.
I was at Stanton, MI alt ~700ft
temp 45°
humidity 50%
Baro 31.2
There's a guy in the drag race section with a bolt on LT1 that ran 11.s. The DA was -1900ft.
Old Jan 29, 2003 | 12:25 PM
  #22
again that ties into my original statement that its better to compare locally.
I think you would not see times like that here.. even though we are near sea level.. http://www.houstonraceway.com is our local track..
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
