I've Bypassed VATS, Replaced the Starter and Battery....Still has Starting Problems.
Old Jul 10, 2011 | 10:01 PM
stars1010's Avatar
For weeks now I knew my VATS was going out. The security light has been on solid everyday while driving and it would take 3 to 5 seconds and sometimes two key turns to start the car.
I bypassed VATS using resistors successfully today, no more light, but the car still takes 3 to 5 seconds to turn over.
I had my battery tested today. Pepboys said it was bad. I bought a new one and it still takes my car a few seconds and sometimes two key turns to turn over.
I then thought it could be the starter. It seem logical at the time. After a quick trip to Autozone an hour later I have a new starter in the car. STILL ...... SAME .... DAMN.... THING...... My car takes a few seconds and sometimes two key turns to turn over.
Once it starts my Camaro has totally normal operation. The ignition system seems to be working fine. I put new plugs and wires in last Fall when I installed my long tubes.
Any clue why it takes my car such a long time and rough time to turn over? I'm lost here.
The car is a 2002 Camaro Z28, 6 -Speed with just bolt-ons (Long tubes, cutout and lid).
Old Jul 10, 2011 | 10:03 PM
Melee Penguin's Avatar
Re: I've Bypassed VATS, Replaced the Starter and Battery....Still has Starting Proble
Old Jul 10, 2011 | 10:04 PM
stars1010's Avatar
WTF is that?
Old Jul 10, 2011 | 10:05 PM
CaliChevyLover's Avatar
Ya for real.
Old Jul 10, 2011 | 10:06 PM
mdenz3's Avatar
Have you checked the ignition switch?
94Camaro_Z_28's Avatar
Check the contacts internally in the ignition switch itself that's bolted to the steering column.
Old Jul 10, 2011 | 10:16 PM
stars1010's Avatar
Where is the ignition switch?
Old Jul 10, 2011 | 10:17 PM
GUTTERbOY's Avatar
Old Jul 10, 2011 | 10:18 PM
stars1010's Avatar
Never mind, found a topic on this on LS1tech.
WTF is that?
The Vault-Tec Assisted Targeting System
Duh!
Old Jul 10, 2011 | 10:20 PM
stars1010's Avatar
Originally Posted by GUTTERbOY
I saw mdenz3 post not 94Camaro_Z_28
....So.....
Old Jul 10, 2011 | 10:21 PM
Blue89Bird's Avatar
Turn key, wait to hear fuel pump, then start it. is it any faster?
Old Jul 10, 2011 | 10:27 PM
stars1010's Avatar
That's an interesting idea, you may be onto something. After the I did everything above I turned my key to on (not start) for a few seconds and let the security light go off then fired it up. That was the shortest/best start time I've had today.
Could by fuel pump be going out or fuel filter be ready to swap out?
Old Jul 10, 2011 | 10:40 PM
I do that with my cars every single time, fuel pump/filter/regulator etc all new. still helps start it faster/easier.
Old Jul 10, 2011 | 10:59 PM
KWKSLVR's Avatar
S.E. Region Moderator
My vote is Fuel Pump
