IMPORTANT: 5.3l LS1?
Old Jul 12, 2005 | 10:44 PM
  #16
Z284thgen's Avatar
Re: IMPORTANT: 5.3l LS1?
Originally Posted by ChvyS10Lowrider
thank you very much, at least someone could answer my question, so if I can swap parts from the LS1 into the 5.3 block then I am happy with that, I just dont see only a 60 rwhp gain from 9lbs from any supercharger, much less one of the highest rated and most reliable
no problem man
my daily driver is the 4.8 in a reg cab short bed auto LT's, duals, cam and springs with tunning stock vertor unlocked
www.performancetrucks.net some pretty helpful people over there as well as me
Old Jul 12, 2005 | 10:46 PM
  #17
engineermike's Avatar
Powerdyne highest rated and most reliable??? That's the first I've heard that. Prochargers and Vortechs will make far more power and quality and reliability of their kits is tops.
Anyone who ports heads for free, I wouldn't use. I've talked to some of those guys and they really don't understand the finer points of head porting. Stick with the big names in LS1 head porting if you just have to have ported heads. Otherwise, don't touch them - they flow pretty good stock.
If you had $4000+ to work with, I'd put in a 5.7 or 6.0 with a Thunder Racing dyno-proven cam. It'll make ~400 rwhp from a simple combination.
Mike
  #18
ChvyS10Lowrider's Avatar
yea thanks a lot, the only reason I wanted the LS1 parts to bolt up was the lsx manifold and reusing some parts of my dad's old engine, he totally rebuilt it and left a lot of parts for nothing, so I wanted to at least be able to bolt them up to it
Old Jul 12, 2005 | 10:48 PM
  #19
Originally Posted by Z284thgen
why you say no my 4.8L made 303 to the wheels SAE corrected...
I didn't say 300 rwhp was not possible with a 5.3.
500 rwhp is not possible with a 5.3/Powerdyne.
Old Jul 13, 2005 | 09:40 AM
  #20
97z28/m6's Avatar
if its got an alum block then its more then likely a 5.7 block as all the 4.8,5.3,6.0 are an iron block...the 4.8,5.3 heads are the same
as far as intake the truck intake is really close to being as good as the LS6 intake.. many test have been done do a search on ls1tech.com you will find some good info on it
all the GEN III motors will swap around parts 4.8,5.3,5.7,6.0 but the 8.1 wont swap out
the SSR and the new GP GXP both use an aluminum 5.3.
Old Jul 13, 2005 | 01:51 PM
  #21
dyers98's Avatar
Man, that's alot of conversation for one easy question. Yes, the parts are interchangable and yes, the 5.3 in most cases is aluminum which isn't the best for a blower.
If you can get a 5.3 cheap, great. It's a damn good motor. If you have the cash, get the 6.0 iron block, dump a N20 kit and/or cam on it and do your suspension.
The only problem I see with your 5.3 idea is why not do the 6.0 or even a 5.7 and get more for your effort. The 5.7 will kick-*** with a good cam. Remember there is plenty you can do to these motors to get a ton of power that doesn't include a procharger. My bud just picked a forged LS1 - 427 for 7g's with computer. The car it came out of was laying down 485 at the wheels all motor.
Old Jul 13, 2005 | 04:07 PM
  #22
here is what I say about the 5.3, one it saves me money(im only 16 ya know) two, it can be bored out to a 5.7 or even a 6.0 and stroked for much cheaper, and three I could build it with hte money I save from buying it as opposed to a 5.7 block or a 6.0 block, so that just works out for me a lot better, and I do believe I may sell the 4.3l with the supercharger as a set with the jet coated headers on it, and prolly have around $4500 to spend on cam heads and whatever else I want, prolly gunna do a cam with lsx manifold and some other parts, like bigger injecters and 90mm throttle body, and some show parts
Old Jul 13, 2005 | 06:53 PM
  #23
You should check this, but I don't think a 5.3 can be easily converted to a 5.7 or 6.0 at all. Those are 3 different blocks. Even if you can, it certainly won't be cheaper than starting with a 5.7 or 6.0 to begin with.
Look. . . you decided before even posting this that you're getting the 5.3, so no matter what anyone says, you're going to get it whether it makes sense or not.
Mike
Old Jul 13, 2005 | 10:46 PM
  #24
dyers98's Avatar
I'm not sure what you're paying for the 5.3? But I see 5.7's being sold all day long for $2500 with tranny and computer. By the time you add the cost of the 5.3 and what you have to do to get the power you want...just doesn't make much sense. Plus the effort to copnvert the s-10???? I think you would be much happier with the 5.7. Oh and by the way, you can't bore anything off the LS1's with out some serious machine work..look at the sleeves, what you have is what you have. Good luck though
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
