Idle Problems Plz. help
Old Mar 10, 2006 | 02:40 PM
camaro02DK's Avatar
Hey there
My camaro 02, has been sitting for like 4 months now.. (****ed up my tranny and rear end)
So got all that new installed.
So now I have an idle problem, my idle is going between 400-500 rpm. and you can hear is going up and down all the time when the engine is hot. When I for example go in reverse and then goes to D (automatic) it will sometimes also stall.
I hope one of you guys have a good idea what it could be, or what I should check.
BR
Soren
Old Mar 10, 2006 | 07:34 PM
littlbasterd's Avatar
Re: Idle Problems Plz. help
try cleaning your mass airflow and your throttle body..behind the blade and also remove the IAC clean the IAC and the port is goes in..build up could cause these problems
Old Mar 10, 2006 | 09:03 PM
iamsickofitall's Avatar
did you put stabil in the gas tank before you stored the car? try adding octane booster to the tank and see what it does after a dozen or so miles.
Old Mar 10, 2006 | 11:52 PM
AL SS590 M6's Avatar
Moderator
Reset your computer then start the motor and let it idle for a while. Then turn on the AC and let it idle some more. It need to relearn the idle.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
