Idle problems, car seems very sluggish
Old Jan 13, 2007 | 11:05 PM
sills1's Avatar
I've been noticing some problems when my car is idling. It's actually died a couple of times on my wife while she was stopped at a red light. I also notice a slight hesitation when I give the car gas to take off. I have 72000 miles on the car (2000 SS). I have yet to change the spark plugs, but I'm wondering if there is something else that I should take a look at also (fuel filter maybe).
Old Jan 14, 2007 | 03:39 AM
AL SS590 M6's Avatar
Moderator
The fuel filter should be changed every 30k or so.
Old Jan 18, 2007 | 08:12 PM
metallicsniper's Avatar
you may have a faulty TPS (Throttle Position Sensor) that can cause your car to idle bad and hesistate. hope that helps
Old Jan 20, 2007 | 10:01 PM
Don350k's Avatar
is the check engine light on? usually w/ plugs obd2 will pickup on the missfires ect if so get the codes from your local parts store and let us know the number
Don
Old Jan 28, 2007 | 08:33 AM
NEWBIE T/A's Avatar
Lightbulb One thought on the idle side :
The throttle butterfly has a tiny hole in the bottom of it that allows for idle air when the throttle is closed.
If this is gunked up, idle could be affected although no idea if this would cause any hesitation problems or not.
It's easy to look at - remove the rubber air bellows from the front of the throttle , and you will be able to see it.
Here is a pic - from
http://www.installuniversity.com/ins...ar/tb_swap.htm .
Britt
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
GigaMp3z
Feb 20, 2003 02:57 PM
