I heard 98's dyno lower...
Old Jun 14, 2004 | 08:29 PM
  #31
falchulk's Avatar
Originally posted by trackbird
I know the '02's have the Z06 clutch (not sure on the 01's) and there is no egr on my 2002 and I bought it new from the dealer and did not remove it myself. I'm very sure about both of those.
Yeah, I know there are no EGR's on the 01 and 02 (I ave an 01), what I did not know about was the z06 clutch. I never heard that before.
Old Jun 15, 2004 | 04:03 PM
  #32
94ZRiCeKiLr's Avatar
is my 98 a bit of an overachiever????
337/349 rear wheel, untuned with a 11.9:1 A/F ratio?
Old Jun 15, 2004 | 10:51 PM
  #33
ratio411's Avatar
You have alot of mods though...
Sounds about right.
Old Jun 15, 2004 | 11:32 PM
  #34
Sounds about right.
o yea i know i didnt mean ET wise i just meant power wise...all i really have building power is full exhaust, a lid and a pulley. most of the full-bolt-on cars i've seen were running mid 320s (autos i mean)....im figuring there must be another 7 or 8 horses at least from a tune...given the fact that my timing curve is stock and my air/fuel is a little on the rich side.
Old Jun 16, 2004 | 01:29 AM
  #35
Cool Z's Avatar
My wifes 98 Formula with a lid and B&B cat-back put down 312HP 328TQ and it was a 6 speed. My 2000 Z28 with a lid and B&B cat-back put down 325HP 330TQ it was a 6 speed and has 241 heads. My 2002 SS 6 speed with a lid and B&B cat-back threw down 320HP 340TQ with stock LS6 block. I know it is a little repetative and apologize. Anyways there is quite a bit of mis-information here reguarding the clutches. The 02 that I have did not have an LS6 clucth in it from the factory. I know because I replaced it with an 02 LS6 clutch. The clutch disk and pressure plate that I pulled from my 17000 mile 02 SS have the same part #'s as the stock LS1 spec clutch for 01-02 f-bodies and 01-03 LS1 Corvettes that I bought from GM and installed in my 2000 Z28 and not one # matched anything on any of the 02 LS6 clutch components with the exception of the flywheel. I have a friend that is a parts man for a Chevy dealership and I looked into all of the different clutches for our cars. There are 2 now. One for LS1 powered Camaros, Firebirds and Corvettes and another for LS6 powered Corvettes. GM did upgrade the clutch in 01 which is better than the 98-00 clutch but not much.
Old Jun 16, 2004 | 06:11 PM
  #36
trackbird's Avatar
http://www.lgmotorsports.com/OCLS1_C...ansmission.htm
"A great improvement over the factory 1997-00 LS1 T56 clutch. A factory replacement for 2001-02 T56 cars."
They built a "Z06 equivalant" for the F-body. This had stronger damper springs (33 nm per degree as I remember) and a different pressure plate, etc. It was this clutch that was factory in the 2001-2002 cars.
Old Jun 16, 2004 | 06:19 PM
  #37
ssvegas's Avatar
well since we're all comparing our numbers
my 00 m6 with no mods, not even a lid, put down 300/312.
oh, how do i know what heads i have??
Old Jun 17, 2004 | 01:35 PM
  #38
Cool Z's Avatar
Orginally posted by: Trackbird
The 02 LS6 clutch is an upgrade for 01-02 cars. It's all in the part numbers. The 01-02 F-bodies and 01-03 LS1 Corvettes came with clutch kit 12572731 which is not an 02 LS6 clutch. And as I stated in my original post the 01-02 clutch is a little better than the 98-00. The flywheel, pressure plate and clutch disk that I pulled out of my 02 SS are the same numbers that come in the 12572731 kit which again is not an 02 LS6 clutch. Z06 equivalant does not mean it is the same by any means thats just what LG wants you to believe so you will think "Oh my 02 stock clutch is gone at 20k and it was a $350 LS6 clutch...I better get that $500 Star. That is called marketing for $$.
Old Jun 18, 2004 | 04:26 PM
  #39
Snowmann's Avatar
Dyno in sig. Bone stock. Traps @ 103 on a 85 degree day with fairly high humidity. And yes 98s lack low end it runs 2.3 60 fts dead hooking on slicks, pretty slow 60ft times.(13.7et)
Old Jun 18, 2004 | 07:35 PM
  #40
gav'spurplez's Avatar
my1st and only time to the track i got 2.110, 2.104, and 2.048 on street tires, 60ft times.
13.69 @ 103.5 all day. all i had was a flowmaster muffler and a K&N filter. i am anxious to see what i get now, and with my headers next month
Old Jun 18, 2004 | 11:43 PM
  #41
nikkev's Avatar
Hmmm, not so sure about that man. I pulled 2.0 60' over and over on street tires with my '98 A4. My only mods were a lid and cut-out. I did notice that my 60' times got worse when I used drag radials so I think those ET streets are causing you to bog. Get a stall and that problem will be solved. I put in a Yank 3200 and dropped .3 in the 1/8th mile.
Old Jun 19, 2004 | 08:53 PM
  #42
BirchMan98z's Avatar
LOL my best 60' time ever was 1.8 on NITTO DR's... 98-99 cars are a little on the weak side say from about 1000-2800RPM. After that they have what seems like endless thrust.
Old Jun 20, 2004 | 02:06 AM
  #43
thats why i stalled right over that....
1.6s all day long on 17 inch drag radials...
Old Jun 20, 2004 | 06:48 AM
  #44
sure... but that's with an auto. LOL not so easy with a 6-speed.
Old Jun 21, 2004 | 04:43 PM
  #45
Snowmann's Avatar
Converter is on the way,(Vig 3200 should be here by the end of the week) and it does reallly come on strong after 3000 rpm, just a bad combo of 2.73 and no power under 2500.
