I heard 98's dyno lower...
I dont think the 98-00 cam is "better".
its specs show it to be larger but not better.
The cam in 98-00 seems to lack low end power whereas the 01-02 have power all over the place..
just my observations..
anyone please explain any differences in ls1 heads (the 241 head?) the differences i was aware of were the 01-02 had the ls6 intake and cast iron exhuast manifolds that supposedly flow better. also they changed the egr. however the 98-99 cam has 498 lift vs only 473 lift 01-02. please point out any other changes you can think of. thanks.
I dont think we have EGR at all..
98-99 tubular exhaust
00-02 cast iron manifolds
98-00 LS1 intake and EGR
01-02 LS6 intake
98 perimiter bolt heads
99 and most 00 #853 head castings (my 00 had 241s)
01-02 #241 head castings which are said to be an improved casting from the #853
some 00-02 have LS6 style motor castings too.
98-00 cam has more lift but 01-02 cam has different valve timing giving them a broader power band.
Originally posted by Loony
...whats the oil pump problem?
Sorry about the hijack guys, but I just bought a '98 LS1/4L60E
to put in my S10 and I would like to know about the oil pump
problem too so I can check it before it causes headaches. I did a search and really couldn't find anything definate. Thanks!
the early LS1s had an oil pump that would SOMETIMES fail. not always, I guess there wasn't that much notice when it did. There is a ported LS1/LS6 oil pump I think for about 150-160. Its not very hard to find. But I was under the impression GM didn't fix this issue until late 99
