I accidentaly put too muhc oil in my car.
Old Nov 1, 2004 | 09:06 PM
z28sspeedracer's Avatar
Hey guys, while changing the oil, I noticed I added about half a quart extra past the line. Is this harmful?
Old Nov 1, 2004 | 09:09 PM
MysticTeal 95 V6's Avatar
Re: I accidentaly put too muhc oil in my car.
I don't believe it would hurt anything... most LS1's would have that extra oil burnt up w/ in a couple thousand miles anyways If you're really worried about it... you can always loosen the plug on the oil pan and let some of it leak out.
Old Nov 1, 2004 | 09:28 PM
94ZRiCeKiLr's Avatar
half a quart probably isn't worth it but if you wan't you can either 1) loosen the plug like Mystic said or buy a cheap siphon pump at the auto-parts store...you'll find at least a few uses for it over time, particularly anytime you overfill something that doesn't have a drain plug (ie: tranny/rear etc.)
Old Nov 7, 2004 | 09:10 AM
99snkklr's Avatar
According to the manual the LS1 gets 5.5 quarts but I always use a full six. I also use the K&N long style oil filter which helps with the extra 1/2 quart.
Old Nov 7, 2004 | 03:59 PM
Erik 94TransAm's Avatar
I put 6 quarts in mine as well-it will be fine
Old Nov 7, 2004 | 08:42 PM
ULTIMTEORANGESS's Avatar
i always have six in mine.
youll be fine.
Old Nov 8, 2004 | 10:15 AM
4U 2 NV's Avatar
ive thought about doing this also. using the longer filter. however the stock one is flush with the bottom of the pan. a longer filter would stick out below the line of the pan. im always worried i might hit it on something.
Old Nov 8, 2004 | 02:47 PM
bond449798's Avatar
i used a bigger filter on mine mobli-1 i think it was a 206 part# it does not
hang that much lower than a stock one still have plenty of room.
Old Nov 9, 2004 | 04:54 AM
AL SS590 M6's Avatar
Moderator
Ditto for our 2 LS1 cars and the truck. And 6 quarts in at the change.
Old Nov 9, 2004 | 05:02 AM
BirchMan98z's Avatar
rumor has it 7 quarts is the factory fill? Don't know if anyone can confirm this. Either way, TOO much oil can force a leak.
Old Nov 9, 2004 | 05:03 AM
Hangs maybe an inch lower, no sweat there. My SLP headers hang way down low, cats & y-pipe even lower, and I rarely scrape anything unless I have 2 passengers. You'd really have to bottom out HARD to scrape the oil filter, that's like a foot... We're talking bathtub sized potholes there.
Old Nov 9, 2004 | 12:22 PM
NEWBIE T/A's Avatar
Thumbs up Perfect Timing !
I just used a free oil change coupon yesterday @ Pep Boys, and lo & behold - the work order read 6 quarts for a 5.7 motor ...
Of course, these are the same guys that managed to get grease on my floor mats - I guess since it was a free oil change, a paper mat was just too much to ask for, eh ?
I got it out with soap & water, so life is good again.
I hate not having a house & therefore a place to change my own oil !
Britt
P.S. I burned about a 1/2 quart in 4300 miles w/ dino oil - with synthetic I would burn a 1/2 quart in ~ 3K.
Old Nov 9, 2004 | 01:29 PM
bond449798's Avatar
In the manuel for my car it says 5.5 quarts
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
transam_388
Mar 15, 2015 11:53 AM
Sandersen511
Jan 13, 2015 03:49 PM
