Hpp3
Old Apr 14, 2003 | 01:27 PM
  #16
abarus's Avatar
Thanks, He sent it. I also sent the package via UPS. Your dad has all the tracking information.
Old Apr 15, 2003 | 01:49 AM
  #17
GoFast908Z's Avatar
Member
Thumbs up
thanks. I'll let you know when it gets here and everything is cool.
Old Apr 21, 2003 | 12:51 AM
  #18
GoFast908Z's Avatar
Member
Talking
I got it. I installed it. I Really felt it.
My girlfriend said it sounded louder too. It is much smoother and faster off the line. Thanks!!!
Old Apr 23, 2003 | 03:09 PM
  #19
abarus's Avatar
Your Welcome! I'm glad you liked it and could use it.
Have fun
Old Apr 23, 2003 | 04:54 PM
  #20
Style's Avatar
Originally posted by AL SS590 M6
Any mod that leans the mix (most MAF mods, some exhaust mods) will cause detonation. Then you'll have to pull the power tuning. Some cars with no mods don't like the power tuning. I had 2 degrees of knock retard on any WOT runs in warm weather with it. So I ditched it and got a Preditor which allows the end user to make small timing adjustments and still run the power tune.
I guess i don't see how freeing up the intake or exhaust is going to lean up the mixture. If you have more air being consumed, more fuel is going to be added. Additional air is monitored by the MAF, which would richen the mixture to match the a/f table. So if the a/f table is modified with a programmer, the fuel mixture should stay the same, right? Or am i missing something?
Old Apr 24, 2003 | 02:55 AM
  #21
AL SS590 M6's Avatar
Moderator
The part that your missing is that it's not a perfect world and modded MAFs (home port, MAF ends, and Granitellis it seems) lie to the computer so that the car will run a little leaner. That's where the power comes from.
Now if you've got a MAF that isn't reporting the correct numbers to the computer, then put in a power program that tries to squeak out every ounce of timing available and you get detonation/knock retard.
If an aftermarket MAF reports the correct amount of air flow to the computer then your theory will work. But in most cases that doesn't happen.
Old Apr 24, 2003 | 05:30 PM
  #22
Style's Avatar
Yes, i do see your point with the MAF. But headers or cat back? That sould not change the a/f ratio. Nothing is being lied to, right?
Old Apr 24, 2003 | 11:45 PM
  #23
Moderator
The only way that headers mess with the computers natural ability to keep the motor in tune is that all of the formulas and tables in there are based on the maximum exhaust velocity of the stock system. And it has no way to tell that the velocity is much higher than the stock capabilities. It just tries to maintain the air fuel ratio based on those constants which are now wrong. It can tell the flow of total air thru the motor by the maf readings but the scavenging of the cylinders is different.
I hope that I explained it well enough to understand.
quicksilver97ta
West South Central
Jul 16, 2003 11:30 AM
sleeperZragtop
May 13, 2003 04:02 PM
sleeperZragtop
Apr 5, 2003 12:51 AM
bbentley40
Nov 25, 2002 03:18 PM
DarCwuN
Nov 18, 2002 08:34 AM
