Hpp3
Originally posted by AL SS590 M6
Any mod that leans the mix (most MAF mods, some exhaust mods) will cause detonation. Then you'll have to pull the power tuning. Some cars with no mods don't like the power tuning. I had 2 degrees of knock retard on any WOT runs in warm weather with it. So I ditched it and got a Preditor which allows the end user to make small timing adjustments
and still run the power tune.
Originally posted by Style
I guess i don't see how freeing up the intake or exhaust is going to lean up the mixture. If you have more air being consumed, more fuel is going to be added. Additional air is monitored by the MAF, which would richen the mixture to match the a/f table. So if the a/f table is modified with a programmer, the fuel mixture should stay the same, right? Or am i missing something?
Now if you've got a MAF that isn't reporting the correct numbers to the computer, then put in a power program that tries to squeak out every ounce of timing available and you get detonation/knock retard.
If an aftermarket MAF reports the correct amount of air flow to the computer then your theory will work. But in most cases that doesn't happen.
The part that your missing is that it's not a perfect world and modded MAFs (home port, MAF ends, and Granitellis it seems) lie to the computer so that the car will run a little leaner. That's where the power comes from.
The only way that headers mess with the computers natural ability to keep the motor in tune is that all of the formulas and tables in there are based on the maximum exhaust velocity of the stock system. And it has no way to tell that the velocity is much higher than the stock capabilities. It just tries to maintain the air fuel ratio based on those constants which are now wrong. It can tell the flow of total air thru the motor by the maf readings but the scavenging of the cylinders is different.
I hope that I explained it well enough to understand.
sleeperZragtop
Apr 5, 2003 12:51 AM
