How much rwhp can LS1 bottom end handle?
Old Sep 2, 2003 | 10:38 PM
InGodITrust's Avatar
I am kind of curious as too how much rwhp can a stock LS1 bottom end handle? I've seen some ARE and MTI engine packages claiming 430+ rwhp. How will the bottom end stand up to this? How about with a 75 NOS shot on top of that?
(thinking about trading the 95 for a 98+ and starting to plan!!)
Thanks!
Old Sep 2, 2003 | 11:05 PM
Mikael's Avatar
If you do everything right, 500rwhp should not be a problem. Over this and you will have reliability issues. Keep in mind, you do not have much room for error, so don't go lean and don't knock.
Old Sep 3, 2003 | 08:15 AM
stealth2's Avatar
I made 650 rwhp all last year with no problems and no damage.
Old Sep 3, 2003 | 09:10 AM
Mikael's Avatar
Completely stock shortblock (even 10.1:1 CR)?
Old Sep 3, 2003 | 09:59 AM
stealth2's Avatar
Yep, bone stock 10.1:1 GM short block on blower and NOS made 647 hp and 50 runs, and looked perfect when we took it apart.
Old Sep 3, 2003 | 09:30 PM
ULTIMTEORANGESS's Avatar
wholly **** now thats impressive.what psi and other mods did you have?
Old Sep 4, 2003 | 08:15 AM
stealth2's Avatar
Last year, 346, Vortech SQ, 150 dry shot, Comp cam, Hooker, 4L60E, Moser, Hoosier, 300 cfm heads,
Old Sep 4, 2003 | 07:10 PM
LBJ's Avatar
LBJ
Guys, that is hard to swallow! I've heard from a major player in F-Body performance that anything over 450rwhp and the factory pistons are on borrowed time!! This company builds engines has a chasis dyno and again is a sponser on this board!
Old Sep 4, 2003 | 08:26 PM
chevy qc's Avatar
those are the same people that say once you break into the 12's with a 10 bolt you're on borrowed time. well, some run well into the 11's with them. still borrowing time but still running.
Old Sep 4, 2003 | 08:30 PM
stealth2's Avatar
That car ran 10.30 at Vegas Super Chevy Show last November with a DA of 2,500. If you will pull out your calculator, 647 rwhp at 3,600 lbs. works out a be a bit better than 10.30.
There are a dozen people in Denver who can vouch for those numbers. But then again, that car has been transformed into a 414, low 9-second car with a CI block, YS-trim and wet shot.
BTW, sponsors benefit from having you believe that stock parts must be replaced.
Old Sep 4, 2003 | 09:31 PM
danziger's Avatar
Talking
My stock bottom end took 7 near 500rwhp runs in a row on the dyno without even a hiccup. It will soon be above 550rwhp and I plan to beat it until it explodes. I'll let you know how long it holds up!
Old Sep 4, 2003 | 10:05 PM
stealth2's Avatar
Take a little timing out of it and it'll make 700.
Victor Lamb
Aug 26, 2017 02:52 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Killer94z
Jan 13, 2015 12:06 PM
