How much oil does your ride consumer per 3k miles?
Old May 17, 2004 | 04:33 PM
RealQuick's Avatar
Is 1 qt every 3k normal, or is this excessive?
Old May 17, 2004 | 04:43 PM
PhantomTA's Avatar
Moderator
none that ive ever noticed
Old May 17, 2004 | 05:13 PM
SFB767's Avatar
I just changed my oil yesterday and it didn't seem like the motor consumed any oil.
After making 6 consecutive passes at the track a few weeks ago, I would have thought it might have, but it seemed like it all drained into the pan.
Old May 17, 2004 | 09:21 PM
rncotton's Avatar
I drink 1 quart for 1K miles.
Old May 17, 2004 | 09:53 PM
Lt1 and Ls1's Avatar
1/2 quart for 3000 miles. has since the car was brand new.
Old May 17, 2004 | 10:00 PM
trackbird's Avatar
I use about 2.5 to 3 quarts in 5K. LS1's seem to think they are diesels at the rate they like to burn oil.
Mine is a 40K motor that has been run on synthetic for it's whole life (minus break in time).
Old May 17, 2004 | 10:21 PM
gav'spurplez's Avatar
I change my oil every 3 months, which is usually about 15-1800 miles. I do not need to add or top of the oil ever
good thing i guess
Old May 17, 2004 | 10:28 PM
ZIPPERR's Avatar
Same here
Old May 18, 2004 | 07:56 PM
jay g's Avatar
98 ls1 with 82,??? miles now and no oil usage at all, changed every 3000 miles with synthetic
Old May 19, 2004 | 01:39 PM
mitchntx's Avatar
90K miles on my 98 TA ...
The last 20K have been primarily road course miles.
I will use 1/2 to 3/4 qt in a 20 minute session. The car got hot last summer and oil consumption began.
I will use about 1/2 qt in 2K miles on the street.
I have used Havoline 10W40 for the whole time.
Old May 19, 2004 | 02:45 PM
T.V.'s Avatar
ZERO
Old May 19, 2004 | 03:45 PM
94ZRiCeKiLr's Avatar
Originally posted by T.V.
ZERO
same
Old May 19, 2004 | 05:44 PM
Ken S's Avatar
about 1/2 to 3/4 every 3-4k miles
Old May 19, 2004 | 07:31 PM
LWM's Avatar
LWM
In my LS-1 car, about a qt every 1,500 miles, since new, I drive at higher rpms with light throttle application. Never see smoke, if that is what you're getting at.
I have an LT-1 car also, it doesn't use any oil to speak of.
Apparently some of the LS-1 engines have low tension rings ... and that leads to increased oil consumption.
Hope this helps
LWM
Old May 19, 2004 | 09:40 PM
mcflyz28's Avatar
A quart every three months when it gets changed.
