How much oil does your ride consumer per 3k miles?
Old May 19, 2004 | 10:09 PM
  #16
psychocabbage's Avatar
I only change when the light tells me to..
I have gone over 9K miles btw an oil change..
Always synthetic..
no oil loss at all..
Old May 19, 2004 | 11:10 PM
  #17
SSBIRDMAN's Avatar
1 litre / 5000kms. i usually change the oil at the 1 down level. has done this since new
Old May 19, 2004 | 11:24 PM
  #18
RealQuick's Avatar
thanks for all thge responses guys and gals
Old May 21, 2004 | 01:17 PM
  #19
NEWBIE T/A's Avatar
Lightbulb Holy Shazbot !
Always synthetic..
I follow the light as well, and have never made it over 5K w/ synthetic.
I actually have dino in it now - we will see how long it lasts.
W/ Syn oil , I use between 1/2 & 3/4 qt every 3K.
The car has a 2800 stall - that may make a slight difference.
Britt
Old May 21, 2004 | 06:02 PM
  #20
trackbird's Avatar
The oil light can't tell what oil is in the car. It uses a series of calculations that are based on temp, rpm, load, etc to judge the oils lifespan. It is a "dumb" system that can't actually measure the oil for wear. But if you are running synthetic (and it is set for regular oil) you should be quite safe to follow it. I ignore mine and change oil every 5K with Mobile 1.
Old May 21, 2004 | 07:20 PM
  #21
ss rally red's Avatar
I run Mobil 0w40 syn. the last oil change at 3k included close to 20 passes plus regular driving, less than 1/4 qt.
Old May 21, 2004 | 08:30 PM
  #22
Buffdaddy's Avatar
I probably use one to two quarts between changes.
Old May 22, 2004 | 12:57 AM
  #23
Greed4Speed's Avatar
I ran synth this past oil change and had to add 1/2 qt at 3k. With dino oil, it never used any.
Old May 22, 2004 | 09:22 PM
  #24
rotwiler's Avatar
At 3,000 miles I have zero oil to add. Always used synthetics, currently using Mobile 1 0w40. If I wait until 4-5000 miles I may add a 1/4 of a quart, but it is rare.
Old May 23, 2004 | 12:42 AM
  #25
trackbird's Avatar
I just changed mine today. I got just over 5 quarts out of it (of the 6 that I fill it with) at 4,500 miles. So, this time it only used 1 quart. At one point, I put in 6, found it a little low, added one, went autocrossing and got 4 out a little later when it was changed (total use 3 quarts). It seems to vary on my car.
Old May 23, 2004 | 01:24 PM
  #26
RealQuick's Avatar
Thanks for all the input. I have been looking to purchase an LS1 and just wanted to see what the acceptable limits are.
Old May 24, 2004 | 01:21 PM
  #27
OneSickSix's Avatar
125000 miles on my motor.. Uses none
Old May 24, 2004 | 01:49 PM
  #28
stealth2's Avatar
Re: How much oil does your ride consumer per 3k miles?
Originally posted by RealQuick
Is 1 qt every 3k normal, or is this excessive?
Excessive.
Old May 25, 2004 | 04:26 PM
  #29
Black01_Z's Avatar
1 qt every 2k miles or so.
Old May 26, 2004 | 12:43 AM
  #30
RS Dragster's Avatar
I threw another quart in last week, and I just hit the 5K mark with Mobil 1.
