How hard is it to install a new set of heads?
Old Dec 24, 2003 | 12:03 AM
JDohn2001's Avatar
I am looking into buying a set of heads from AFR for my '98 SS A4. They are 205cc with 66cc and 76cc combustion chamber volumes available? By the way, what's the difference between "as cast" version and CNCed version. I've never done internal engine work before. But I have done every other mod to my car by myself, including: SLP Lond tube headers w/SLP loudmouth exhaust, SLP air lid, MAF ends, Fast toys ram air, Underdrive pulleys, BMR adjustable torque arm, and new plugs and wires. Please let me know if you think I can do it myself and if I need any special tools for the install.
Old Dec 24, 2003 | 03:26 AM
DARK AGE 53's Avatar
Re: How hard is it to install a new set of heads?
The question is do you think you can do it, anyone can tell you "go for it " but if you have a problem who's going to give you a hand? The best advice I can give you is if you choose to do the install, mark ( using masking tape and a Sharpie ) everything before removing, take notes and if you have a digital camera take plenty of pictures also.
Al
Old Dec 24, 2003 | 07:32 AM
Demon SS's Avatar
To me head swaps are no big deal and don't require any special tools, but then I own/run a small performance shop and have done a number of heads and cam installs. Still all in all it is not that hard or complicated and you can get some very good info at ls1info.com.
As cast mean that the heads have not been ported on a CNC machine.
Old Dec 24, 2003 | 07:31 PM
OnyxXtreme's Avatar
http://www.ls1howto.com
that is jmX's site, read the "head/cam install" page
infact read it a couple of times
its probably the best article on the net
its not hard at all to do the work, easiest way to do it on your first time is to label everything you remove that your not that familiar with
and one of things that most people screw up their first time, is putting the grounds on the back of the heads back on
so keep that in mind
But if I were you, I'de look into getting heads and a cam at the same time.
Old Dec 25, 2003 | 10:09 AM
JDohn2001's Avatar
Thanks for your help, I think I'm going to do a head/cam install this summer.
Old Dec 26, 2003 | 12:22 AM
Bad AZz Z28's Avatar
Tonawanda NY you say? hmm, if you need a hand I could help out, or if you need a shop to do some work I could set you up with that cheap too. I live in T-Town too, and could always use another fbody project to take a look at
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
