How to get in the 12 sec. class with stock LS1
Old Nov 10, 2005 | 06:41 AM
  #46
JakeRobb's Avatar
Super Moderator
Re: How to get in the 12 sec. class with stock LS1
Originally Posted by RS Dragster
Well, what would you consider "pretty damn fast?"
I think anyone pulling a 1.7 60' or faster would definitely be wise in removing the front swaybar and NOT having a STB. When you start launching hard, every little bit helps. It only takes a little time difference in the 60' to make up big in the end. That's why it's figured for every .10 seconds you shave off in your 60', it'll net you .20 seconds off in your overall ET.
Well, regardless of ET, I'd consider a 1.7 60' to be pretty darn fast.
You give this advice without any caveats, and that's where you're going wrong. You don't mention that the car's road handling is going to suck ***** with those components removed. Sure, if your car is a dedicated drag car and trailer queen, remove the STB and swaybar. Any car that's street driven should keep the swaybar. If you never autocross, and you're fairly satisfied with the car's current handling, don't bother getting an STB.
I drag, autocross, and daily-drive my Z28. I'm getting a strut tower brace.
Old Nov 10, 2005 | 07:04 AM
  #47
darrens99formul's Avatar
Originally Posted by 30thTA
How much is it for the TCI SSF 3500 and what are the typical gains in the 1/4 mile? Where to buy it? Are they hard to install? What about labor costs?
They run about $500. Typical gains are .5-.7 in ET and +1 in trap speed(traction is key so drag radials may be a good investment). Texas speed and performance usually has good prices on them. You have to remove the transmission completely so install is a bit difficult without proper lifts, tranny jack, ect. Labor costs are usually $250-$350 depending on where you go. I paid $275 for the converter to be installed and another $50 for the tranny cooler.
Best mod I have done, that's for sure.
Old Nov 14, 2005 | 02:45 PM
  #48
GCEZ's Avatar
12.991 @ 108.151, 2.0 60, R/T .024 on street tires with ONLY one mod: An SLP Cold Air Intake System. That's all, nuttin else, no other bolt-ons.
(79 degrees F, 73% RH, DA 2,111 ft, no spare tire, 1/16 tank of 110 octane gas, 12lbs pressure rear tires, 50 lbs pressure front tires (Goodyear Eagle GS-C's which were the factory tires)
2002 Z-28
Old Nov 14, 2005 | 06:36 PM
  #49
RS Dragster's Avatar
OK, my bad. I guess I could have said that the no STB and removing the front sway bar was for the track only, but I figured most people would be able to figure that out. Besides, it only takes 10-20 min, and can be taken off/put back on in the pits before and after a day at the strip.
Old Nov 15, 2005 | 06:49 AM
  #50
JakeRobb's Avatar
Super Moderator
2002 Z-28
Thanks for all the details, but you forgot to say A4 or M6. Why 110 octane on the stock motor? Wallet getting too fat?
Old Nov 15, 2005 | 06:20 PM
  #51
96WhiteZ28's Avatar
Headers and converter shaved off .9 seconds off my ET. Two of the best mods for the money
Old Nov 19, 2005 | 02:55 PM
  #52
QuickSilver02's Avatar
Re: How to get in the 12 sec. class with a slightly modded LS1
Originally Posted by Greed4Speed
Also take off your front swaybar for the track.
I've heard people say this before. What exactly does this do?
Old Nov 19, 2005 | 09:15 PM
  #53
teal99camarov6's Avatar
weight loss
Old Nov 19, 2005 | 10:19 PM
  #54
Originally Posted by teal99camarov6
weight loss
Is that it? I read something about body flex earlier.
Old Nov 20, 2005 | 01:43 PM
  #55
Greed4Speed's Avatar
Not only weight loss, it allows the front end to rise more planting the rear tires harder.
Old Nov 21, 2005 | 07:27 AM
  #56
JakeRobb's Avatar
Super Moderator
The front swaybar limits body flex in the front. With a big torquey motor, the body wants to twist when you hit it off the line. If the swaybar is there to limit that twist, it will pull some weight off one of the rear wheels. If it's not there, all the weight that should be on the rear wheels stays there.
I really don't think you'll see even a 0.1 difference in a 12.x car.
Old Nov 23, 2005 | 12:01 AM
  #57
Releacez28's Avatar
I think u said it yourself, stall convertor and sticky tires and your all but guaranteed. With a stock LS1 you should be practically at the door anyway. So the convertor w/tires should get it in. Cheap exhaust and lid wouldnt hurt to help push either. If you arent there yet start throwing stuff out, spare tire can go, you only need one seat. Hell you see these guys on pimp my ride!? If i had one of there cars and got caught up in a street race, oh boy i would be chucking everything out as im flying down the road. DVD's, tv's, gone. stereo system out the window.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
