How to get in the 12 sec. class with stock LS1
Re: How to get in the 12 sec. class with stock LS1
I say get the Vigilante convertor. I think its the best u can get. I got a great deal for my vigelante convertor, from a friend that i have who owns a speed shop. He gave it to me for $400 and he said he will put everything in for $350. Right now its getting a 3800 stall. With that and some 3:73, look out
30th, here's how to get in the 12's
12.97@106.66
60ft was 1.97
Mods- Free ram air, lid
Tires -Kelly T rated
Weather was about 50degF
DA was about -350ft
Staging technique was to just barely light the 2nd stage bulb. Bring car up against converter as far as possible and nail the gas as hard and fast as I could. Run was made at Mason Dixon dragway in Maryland.
12.97@106.66
60ft was 1.97
DA was about -350ft
Originally Posted by 30thTA
How much is it for the TCI SSF 3500 and what are the typical gains in the 1/4 mile? Where to buy it? Are they hard to install? What about labor costs?
This may seems like a crazy question but.........How is it that a LS1 M6 is quicker than a LS1 A4 in the 1/4 mile?
Originally Posted by ManicHaze
suspension alone will put you in the 12's no joke. sub frame connectors, and control arms for sure, and then perhaps shock tower brace and pan hard bar etc. engine mods arent required for 12 second passes with a m6, and an auto shouldnt be far behind.
I didn't know that a strut tower brace can hurt you in the 1/4 mile? I have a S.T.B. on my car now. I will see next year if it effects my time or not. I have the storage insurance on it right now and I can't drive it until around May.
You have to be pretty darn fast before a strut tower brace is going to have a noticable effect on your times. If you do the other suspension mods (SFC, TA, PHB, LCA's with relocation brackets), it will more than make up for any "loss" caused by a STB.
Originally Posted by 00cls1camaross
i have been reading about everyone saying get a converter and a shift kit for the A4... and recomendations for brands and how high the stall should be.
-Dakota
-Dakota
Yank ST 3800
TransGo valve body reprogramming kit
B&M 19,000 gvw cooler
lid, loudmouth, SSRA
on ET streets
12.15 @ 110 3 years ago.
I have seen 2 LS1 cars go 12.30s with the same mods, they are:
Drag radials
Remove front swaybar
Lid
cutout
stall converter(larger one)
Turn off torque management in the ecm
Free mods
One had 3.23 gear, the other had a 3.42 gear
Thas it
David
Drag radials
Lid
cutout
Free mods
Thas it
David
I think anyone pulling a 1.7 60' or faster would definitely be wise in removing the front swaybar and NOT having a STB. When you start launching hard, every little bit helps. It only takes a little time difference in the 60' to make up big in the end. That's why it's figured for every .10 seconds you shave off in your 60', it'll net you .20 seconds off in your overall ET.
where do you buy this stuff? and what is it purpose?
Is the valve body reprogramming kit called a manual valve body that allows you to sift your car like a manual with out a clutch?
B&M 19,000 gvw cooler... is just a high performance tranny cooler?
