How do I remove the plastic shroud infront of the radiator?
Old Oct 27, 2003 | 10:47 AM
6speedZ28's Avatar
Ok I am going to the track this Friday for the last time this season. I have a question. When I take off my air lid and take out my K&N...I see the bottom of my air box. I cut out the bottom of my air box but now it looks like their is a plastic shroud that is infront of the radiatior that comes up and then block a good portion of the bottom of the air box...how do I remove this plastic shroud. I figured it would be easy but I can get it out and it look slike a pain in the *** to cut out the top part..and even if I did it looks as though it would still be restricting quite a bit, please help!!
Old Oct 27, 2003 | 11:00 AM
DARK AGE 53's Avatar
I have never done this mod but www.installuniversity.com says to cut it out with a Dremel tool.
Al
Old Oct 27, 2003 | 01:38 PM
the pool boy's Avatar
I tried forever to get that piece out - without success. I ended up cutting away the plastic with a box cutter. It was really easy.
Old Oct 27, 2003 | 01:41 PM
6speedZ28's Avatar
Box cutter sounds easier than dealing with melting platic like you would with a dremel, I'll give that a shot, thanks.
Old Oct 27, 2003 | 04:31 PM
94ZRiCeKiLr's Avatar
its not hard to get out....mine's gone....u have to pull out the two white plastic push pin looking things holding it in in the middle and then u have to give it a good tug to get it most of the way up. you''ll then notice that its caught under the radiator support on something. i can't remember what exactly as i did the free ram air mod a long time ago but if u take ur time and trace the shroud down under the rad. support ull find what its caught on....its not fastened, just kinda stuck in place.....trust me, inspect the thing closer and ull have it out in 10 minutes.
Old Oct 27, 2003 | 08:50 PM
Import_Eating_Z's Avatar
I tried forever to get that thing out... $%%&#@* Ahh just cut it ... like http://www.installuniversity.com/ says But if you can get it out like 94ZRiCeKiLr says then ON
Old Oct 28, 2003 | 03:58 PM
sorry for the vagueness of my advice. i did the mod so long ago i cant remember exactly but trust me it WILL come out just undo the plastic pins pull it up till it gets stuck and trace it down under the rad support to find what its stuck on, mine came out without breaking.....just takes some time...
HarleyZ28
Oct 5, 2015 06:23 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
rjc1629
Jan 27, 2015 10:46 AM
ANDYZ28
Dec 29, 2014 09:13 PM
squarehead
Nov 21, 2014 08:02 PM
