Horsepower!!
Old Mar 2, 2007 | 07:48 PM
  #16
LastBreedLS1's Avatar
what do i gain from having better performance than HP?
Old Mar 3, 2007 | 04:16 AM
  #17
Capn Pete's Avatar
Umm, better performance .
Do you want to "look" fast, or "be" fast? You can have ~400 RWHP but not make use of all of it, and only run ~high 12's. Or you can have ~300 RWHP but with things like stall converters and lower gears, making the most use out of the power you've got, and run mid-low 12's!
The idea is, find how to get the most out of your car with the engine it's got before you start cranking out more HP. Once you think you've found its "limit", then you start increasing HP .
Like the old saying goes, "all the HP in the world is nothing if you can't put it to the ground". Besides, bench racing (dyno #'s) are only cool on the internet!
Old Mar 4, 2007 | 11:54 PM
  #18
of course makes sense to max out what you got, then add more. just making sure that's what was meant, and not twist or over think what you guys told me. im really going to put all this info to use. and give you an update as soon as i get started. thanks!!!
Old Mar 5, 2007 | 07:57 PM
  #19
Greed4Speed's Avatar
A simple term......mechanical advantage.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
